Question about Canon EOS Rebel Ti / 300V 35mm SLR Camera
Film door latch is loose
The film door latch doesn't seem to have the springiness to keep it in the closed position, and thus, if the latch gets bumped it can easily shift to the open position, letting the film door come open and exposing film. Granted, one fix will be to put tape over the latch once it's closed, however, I was wondering how tough it is to change out the latch mechanism itself or to put in some kind of replacement spring in the existing latch. USCamera seems to sell a latch mechanism at http://uscamera.stormer.us/1can050_017.htm
  • brainrot Feb 10, 2008
    In Mine, two small screws fell out and the door latch has no "spring" in it any more. I can not use the camera or the door will open on me.
  • Anonymous Mar 09, 2009
    One of the two screws is missing on the film door latch. Latch has no spring to it now and the door will come open if bumped.
    Master:
  • Canon Master
  • 923 Answers
My crystal ball tells me that you are referring to you vintage 1939 Pentax SLR camera! Is that correct?
Posted on May 12, 2017
2 Suggested Answers
SOURCE:
  • 33 Answers
SOURCE: Film door latch is loose
Same advice I made to another post. At some point you got to make a decision. There is a lot of plastic pieces that can break. Canon doesn't support the T series from what I've read. You may consider getting another one. You also have to consider that the fix may not work. Then what do you do?
Posted on Aug 04, 2009
I have a Pentax ME super and the film door will close when there is no film but when i load it with film its not closing properly?
I really loved your camera type though it was 35 years ago I had one. I envy you.
Not sure why you should be having trouble unless you have a bad film. Have you tried more than one film?
If the film cassette has dropped in properly and is laying flat, the film rewind has to be raised, I think, to allow that and the sprocket holes in the film are properly engaged with the sprockets and the free end of the film engaged onto the film wind-on reel then everything should be well below the door aperture.
I would wind on maybe a frame and fire the shutter prior to closing the film door just to observe everything moving as it should and then close the door.
The last quarter inch the door must be closed against the pressure of a spring but if the little spring-loaded device behind the door which is intended to keep the film perfectly flat against the camera body is working correctly only a light pressure will be needed to compress those springs and close the door.
Perhaps something is wrong there?
I don't remember any problems closing the film door.
I hope this helps but if it doesn't please come back again and describe your actions and the feel of the door more fully.
Feb 04, 2015 | Pentax ME Super 35mm SLR Camera
Pentax ME super advance film doesn't get caught
This is a known fault with this retro model, I'm afraid - over time, the plastic gears get worn, and eventually fail. Solutions are mentioned on the Pentax Forums.
Aug 19, 2017 | Pentax ME Super 35mm SLR Camera
Can't get my camera to advance the film. I put new batteries in but still nothing Is there a particular type of battery I should be using for it??
Hi Susanabbott2, As long as you are using AAA batteries, unless you have the holder for AA batteries it should advance the film. Things to look at: With the batteries in camera turned on do you see the red display in the view finder, if not there is an electrical issue, if you do see it do the following. Open the camera back make sure the leader is pulled to the red marker on the lower right. On the camera back door is there the chrome springy thingy with the little roller? If not then as you close the camera back there is nothing to place tension on the film so that the sprockets can grab the film.
May 06, 2010 | Nikon N2000 35mm SLR Camera
My film won't load
Jammed Advance Motor Assembly.
Feb 27, 2009 | Pentax ZX-60 35mm SLR Camera
Olympus iS-50 film camera with new batteries not working
Film door switch is not working.
When you close door make sure door latch is clicking.
Feb 17, 2009 | Olympus IS-50 QD 35mm Point and Shoot...
Can't close door after loading film.
sounds like the door latch broke. (tape) Canon will only replace/upgrade not repair.
ours cracked after a drop then broke replacing the film.
Jan 07, 2009 | Canon Sure Shot Z155 Caption 35mm Point...
Camera keeps rewinding film
Check the manual rewind button on the bottom plate of the camera. Make sure the button is not jammed under the edge of the button opening. If it is you might be able to carefully pry it out with a sharp pin or tooth pick (be careful not to pierce the button or you could damage the circuit board underneath) Or you could remove the bottom plate and reseat the button (be careful of a loose spring to the film door latch)
Dec 03, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Sep 06, 2008 | Canon T70 35mm SLR Camera
Fuji 35mm Camera (Model DL-400)
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
Jun 11, 2008 | Fuji Discovery 185 Zoom 35mm Point and...
Canon EOS Rebel Ti / 300V 35mm SLR Camera Logo
194 people viewed this question
Top Canon Photography Experts
old marine
old marine
Jerry Greenberg
Jerry Greenberg
Norman Worley
Are you a Canon Photography Expert? Answer questions, earn points and help others
