Question about Samsung HL-R5087W 50" HDTV-Ready Television
Crack in plastic viewing screen for samsung 50 in rear projection
Bp96-01058a (part)ASSY COVER P-FRONT;5 (description)model HL-R5078WX/XAA
This is what I was given. Is this the plastic viewing screen - the outermost screen - the one you can touch?
  • 89 Answers
Yes that looks like it is just the cover, However that's a mighty expensive cover... I found it at https://www.ued.net/ued/addItems.do?itemCode=SSGBP96-01058A
Posted on Nov 25, 2008
    Sergeant:
  • 276 Answers
Its not the viewing screen its the outermost one
  • smarttech Nov 25, 2008
    it wont effect ur viewing screen but it will be seen as a scratch above it.if it is new and under warranty u can get it replaced.
TV wont turn on
a bad power supply is most likely cause of this. Other possible cause is bad main circuit board.
May 03, 2010 | Samsung HL-S5086W 50" HDTV
I have a Samsung Hl-P5063wx/xaa that I recently replaced the bulb (3 months ago) then a week later replaced the color wheel. I now get only sound no picture whatsoever. I hooked up a different tv to the...
Remove projector assembly and clean out dust from cooling fans inside of it. It will require some disassembly. Then have capacitors checked on the power supply.
Apr 29, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Cracked screen
call 800-648-6657 and order part no. KR00631. Screen Assy.
Oct 11, 2008 | Hitachi 60SDX88B 60" Rear Projection...
Open Questions:
Samsung HL-R5087W 50" HDTV-Ready Television Logo
27 people viewed this question
Henry  Thomas
Henry Thomas
