Question about Dell Inspiron 6000 Notebook
My lap topwill not turn on.
My lap top will not turn on. I removed the battery and plugged in the power cord, but the laptop will still not turn on.
    Scholar:
  • 55 Answers
Try to check if your AC adapter has a light itself. If it the light is off. Then try a known good adapter. If the AC light is green, then try to wiggle the cord from the port and see if it ain't loose. Try to also check if the AC pin is not bent or broken.
Posted on Nov 25, 2008
My lap top its not responding to power button and i cant start my lap top
Unplug the battery and the power cord. Hold down the power button for 30 seconds. Plug back in the battery and power cord. Try powering on the laptop. If it powers on you are good to go. If not try contacting Lenovo support.
May 31, 2014 | Lenovo 3000 G530 Notebook
HP Lap top touch pad locked. How to correct please
By now you probably figured out you have to remove the power cord and battery to turn off the laptop. Let it cool down, 30 minutes or so, and then replace the battery and restart the laptop.
Feb 17, 2014 | Computers & Internet
My lap top turns on and then turns off
What model is your laptop? What Operating System?
Remove the Power Cord, Remove the Battery, Remove the screw from the cover that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 26, 2012 | Dell Computers & Internet
Hi I have a Compaq Presario CQ60 Laptop. It is plugged in to external power and the power light is on at the connection point. I can not get any power to the laptop. I have removed the battery once I...
Power cord? In fact if the power cord is bad you will not had a battery charge either,so check this.Also Did you plug the power without the battt? Is this power up th lap? If not the Power cord is the problem.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 03, 2011 | Compaq Presario CQ60-220US PC Laptop
Lap top will not turn on. receives power from the cord and power supply, but has no indicating lights on the lower left part of laptop. was able to get the lap top to operate after removing and...
Measure the voltage at the terminals of the battery in the laptop. If there is no supply then the power section in the lap tops main board is faulty and needs a check.
However if there is voltage then the battery must be checked if this has failed to charge and is defective. check if the cord from the adapter is not short as it will result in DC power cut off.
Mar 24, 2011 | HP Computers & Internet
When i turn on my notebook it is just black..the screen is blank i cant see anything on my desktop
How I tackle laptop screen stay blank after turning on the power switch?
1. Make sure the power is off.
2. Make sure the lap top is not plugged in (charging cord is not plugged in).
3. Remove the battery from the bottom.
4. Hold the power button for 30 to 60 seconds.
5. Plug in the power cord.
6. Turn it on as usual.
If the above instructions doesn't work, try removing and reseating the RAM sticks in the Notebook by following the guides available from page number in the Manual of the Notebook. Try starting the Notebook with one RAM module inserted and do try by inserting one RAM stick in another.
BTW, If not, you can try to buy a Laptop LCD Screen Replacement ( one of my friend got it for replacement in Papatek)
Jan 27, 2011 | Computers & Internet
Hi Charlie, Thank you for your quick reply, The problem is I do not know how to check to see if it is a problem with the battery or if it is with the power cord. Although I am going off of the assumption...
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Jul 18, 2009 | Acer Aspire 3690-2196 Notebook
My lap top just swiched it self off and now just seems as if its dead, when i plug the power cord in nothin happens either, anything i can do?
Try this (works sometimes):
Remove the power cord and the battery. Press the power button for a few seconds. Replug the power cord and power up the laptop. If it works, turn it off, and insert the battery again.
Oct 25, 2008 | Computers & Internet
Battery
ok..remove battery from laptop..plug in ac adaptor, then see if it runs..
Apr 18, 2008 | Dell Latitude D600 Notebook
Lap top not turning on
Try removing the battery, waiting 30 seconds, then plugging it back in. Plug in power cord and try to turn it on.
Feb 02, 2008 | HP Compaq Evo n610c Notebook
Dell Inspiron 6000 Notebook Logo
103 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
