Question about Sharp Televison & Video
I accidentally pressed a button on my friends tv and it start channel searching know he does not get the channels he needs which is really 4 so how do i fix it without a remote
  • 64 Answers
Depending on the model you should look for the menu button. It should located on the side panel or on the front of the set. After pressing the menu you can use the volume and channel up down buttons to navigate to the setup area. Here you can add or delete channels.
Posted on Nov 25, 2008
I hve a philipf sru3006 need code for my tv Symphonic
You can download the manual from
http://www.retrevo.com/d/ds/progress?doc=d74782ab23218f4c972a807a9afa3fc7&rk=0.15356064987977386
To manually program your unit,
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the SETUP button until the red
indicator stays on, then release the SETUP button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
Most users will store VCR codes under the VCR button,
Cable codes under CABLE, etc. If (for example) you
want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and
press CABLE in step 2 of Direct Code Entry, then enter
ANY VCR code in step 3 of Direct Code Entry. Then
follow the steps above for Code Search (or Brand
Search, below). Note: If the device does not have a
CHANNEL UP button, use PLAY (VCR only) or
POWER instead. Code Search starts from the currently
stored 4 digit number under that mode.
Aug 14, 2010 | Philips SRU3006 Remote Control
I need the codes for the sylvania television as i replaced the batteries and then it stopped working my tv
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
Jul 16, 2009 | Philips PM3S Remote Control
Sentry universal remote
I wish someone would bring a suit against any of these manufacturers using the term 'universal.'
At best, they are 'multibrand' and, with the proliferation of 'brands,' there never will be one that can rightfully claim to be 'universal.'
There may never be a code for your brand available in every remote.
The instructions for searching for a code are pasted below stolen from another site:
steps for programing the rmc10 sentry really big universal remote
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Jan 10, 2009 | Philips 20PT6441 20" TV
I have an universal Philips Magnavox remote don't know the model # but I just need to know how to search for the codes. I can't remember how.
These are generic code search instructions for Phillips/Magnavox
Programing with Code Search
1. Manually turn on (TV,VCR,etc.) to be controlled.
2. Press and hold Code Search button until red indicator stays on.
Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.).
The red indicator blinks, then stays lit.
4. Press the Channel Up button repeatedly ( up to 300 times )
The red indicator blinks, then stays lit. If you accidentally
overshoot the code required, press the Channel Down button to
backtrack through the library until the device changes channel.
Pressing Channel Up changes direction to forward again.
Press and release the Mute button to install the code.
If the device you are installing does not have a Channel Up button
use Play(VCR only) or Power, on all other devices.
Jan 03, 2009 | Philips Magnavox Learning Universal Remote
How to set a remote for a philips universal cl034 for a sanyo tv
1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
2. Press and release the desired mode button (TV,VCR, etc.). The red indicator blinks, then stays lit.
3. Enter the 4 digit. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL UP. If the device responds, no further programming is required.
Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes direction to forward again.
Jan 02, 2009 | Philips PM3S Remote Control
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
HI MY FRIEND sreeki.
Try this site:
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
It's the manual for a Phillips remote control. The codes should be rather universal. Otherwise, there is a way to program it without using a code.
Programming with Code Search
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 14, 2008 | Philips Magnavox Learning Universal Remote
Code for Sony tv
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Hope this helps :)
Jun 10, 2008 | Philips Universal PH301S Remote Control
Lost Instruction sheet for cl034
May 12, 2008 | Philips Magnavox Learning Universal Remote
Philips magnavox, universal remote
Hope this helps :)
Apr 23, 2008 | Philips Magnavox MRU1400 Universal remote...
Televison & Video Logo
42 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
