Question about Linksys Wireless-G WRT54GS Router (e125894)
I can't stay connect on-line - Linksys Wireless-G WRT54GS Router (e125894)
  • Linksys Master
  • 4,338 Answers
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
  • 2.4 GHz interference: Your router may be operating on the same frequency as your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 25, 2008
6 light 2 spot light low volt moon Raysystem trouble making a connection on 4They clip onto line fine wont stay lit Is there a way to clip the lights to the low voltage line better so they stay lit.
Not sure what you are needing here but if its a poor connection, try soldering the wiring or using correct spade and socket connectors.
May 25, 2015 | Cars & Trucks
Water heater pilot light not staying lit
Check you have enough gas pressure. At least 19mBar when all appliances are working.
Dec 21, 2017 | Water Heaters
Got a new tranz 380. it won't stay connected .
Your shop has optical phone lines? lol I never heard of such a thing and I used to work for MCI worldcom.
All you need to do is call up Qwest or your local phone provider and have them put in a standard analogue phone or fax line.
Here it would run you about 20 bucks if you dont get it as a business line. maybe 50 if you tell them it is for a business.
Mar 27, 2010 | VeriFone TRANZ 380 Transaction System (X2,...
Blue verticle line is displayin
The blue line is most likely the result of your monitor's screen going bad. One thing you can try is disconnecting and re-connecting your video cables to make sure it's tight and has a good connection. This probably won't help, but it's worth a try. You may also want to connect the monitor to another computer to see if the blue line stays, or goes. If the blue line stays with another computer connected, the problem is inside the monitor. If the line goes away, you should replace/repair your computer's video card and/or cable. Otherwise, you need to replace/repair your LG monitor.
Mar 03, 2010 | LG Flatron L1750S 17" LCD Monitor
Where does the vacuum advance line go on an old rochestor carb
Get a tee fitting for the size of the vaccum line and connect the advanced line into an existing line from the carb. Worked for me on one of my old cars.
May 31, 2009 | Chevrolet Chevy Cars & Trucks
Can't stay connected to the internet with my laptop, but dekstop(which is directly connected to the router) has internet
I'd try calling verizon on the issue first and have them test your line. If that comes back clean, then you need to look at any extra equipment you may have at your house (alarm systems, etc.) that could throw disruption on your line. Also make sure you have filters on your phones!
Hope this helps!
May 19, 2009 | Actiontec GT704WG Wireless Router...
Line 2 stays lit with red light
I think that just means that you do not have a 2-line connection to the phone. Either your cord is a 1-line cord or your 2-line cord is plugged into the wrong jack on the back of the phone,
Apr 14, 2009 | RCA 25202RE3 Corded Phone
Pilot wont stay lit
A short pilot flame not playing on the thermocouple or a faulty thermocouple , loose connection at the gas where thermocouple is ,
blocked pilot flame to small , air in gas line did he purge the gas line first? other wise you will be there a long time .
Dec 16, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Linksys Wireless-G WRT54GS Router (e125894) Logo
81 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
