Question about Venturer PVS1950D Car DVD Player
Video screens My video screens are not working all of the sudden. I've tried both of them and tried switching around the cables, but the screens remain completely blank. They don't even appear to be coming on. Thanks
  • djbaum May 09, 2008
    I have one screen that works and the other is blue.
I am experiencing the same exact problem. I can turn the DVD player on and it spins up, but no signal is getting to either screen.
Posted on Feb 27, 2007
LG Washer not completing spin cycle and says LE
It is either:
1. Thermistor error. $6 part. Easy repair
2. Motor position sensor issue. $18 part. Easy repair
check out repairclinic.com or appliancepartspros.com for repair videos. Thermistor can be replaced from bottom of washer . Videos show you where it is.
Mar 06, 2017 | LG WM-1832C Front Load Washer
Black screen
replace the bulb in the tv
Oct 20, 2012 | ViewSonic N2750w 27 in. HD-Ready LCD...
Samsung laptop screen shows garbage r540
if it's something that occurs with movement, and you had you screen previously replaced i would suspect that the screen cable clip is loose, try re-seating the cable in the back of screen and securing it with some tape to ensure that that it remains clipped in place, i think that this us most likely the issue.
As for the ATI driver i sometimes see that occuring, try updating the drivers.
Oct 15, 2012 | Samsung R540 Laptop
HT-RC360 no longer feeds video to my TV .
Update firmware (usually every 6 months). Connect the ethernet to the unit, press Net and Power button simultaneously. Hit Enter as directed. Takes up to 60 minutes. OR (if no internet service), download firmware updates onto a USB (32MB) and connect it to the USB port. If you do not update voluntarily, unit will suddenly not feed video.
Aug 26, 2012 | Onkyo Ht-rc360 7.2ch Network Audio/video...
Hi, My Samsung UE46C8000 is suddenly showing left half of the screen fine, right half is simply colourful blurry vertical lines. After about 3 seconds the TV then restarts itself, but the problem...
if you have this tv connected to the internet try and see if it needs updating. it also could be the pip settinmg picking up an air signal instead of a cable channel.
Jun 25, 2011 | Televison & Video
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
I have an 52 inch lg5000 tv . it supposed to be full hd. i ve tried to connect my play station 3 via hdmi cable but the only thing i get is the no signal sigh on the screen i ve tried everything . is my tv...
plug the ps in with power cable only no hdmi. When turning on Hold down the power button until you hear a second set of beeps you have now reset the video settings. Turn the console off and plug in your hdmi and switch back on it should now work.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
KVM switch
If you tried to switch the two cables and the problem remains on the 1st cable then definitely the port 1 is already defective.
Jun 19, 2008 | IOGear MiniView GCS62 2-port KVM Switch
Car Audio & Video Logo
217 people viewed this question
Top Venturer Car Audio & Video Experts
Hjalmer Lamminen
Hjalmer Lamminen
Marvin
Marvin
seankane89
Level 1 Expert
Are you a Venturer Car Audio and Video Expert? Answer questions, earn points and help others
