The tv powers on, visio decal changes from amber to white, but no menu, sound, or other function buttons responding except power button.
SOURCE: Vizio VW32LF powers up no sound no picture unplug to turn off
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
SOURCE: Vizio P42 model Sp42 A
I had the same problem. I bought the TV with the same symptoms and couldn't find a solution. So just on a hunch I tried different button combinations on the front of the TV while I turned the main power switch on in the rear. One I got to the Channel up and Channel down the TV came to life and works great. So just hold those 2 buttons down at the same time while you flip the switch on the back. Hold them for about 10 seconds and then you should be good to go.
SOURCE: screen turned black except vertical color lines in the center
good day your vertical ic is defective needs to replace look for qualified technician to fix your tv
SOURCE: 47" two yr old Visio
This is the second time I have seen this problem this week. Seems like a common issue on Vizio LCDs. Anyways the problem you mentioned indicates that the tv-micro IC has failed. THis is located on the main audo/video board and a component level repair is not possible in this case. The main A/V board has to be replaced and it should cost you around 100-125$. Would you like to do it yourself?
SOURCE: My Visio 50" Plasma Model#
Have you removed the back and looked for Bad Capaciotrs on the power supply board?
Capaciotrs will be vented or puffed up on Top. 1000uf 16v,2200uf 10v 3300uf 10v etc....
