Question about Maytag Neptune MAH5500B Front Load Washer
Maytag spinning loud noise
My maytag neptune front load washer makes a loud noise during the final spin when it turns real fast. (loud whinning seems like coming from the large belt pulley..Please help? Other than that, everything is good...
  • 3 more comments
  • Anonymous Mar 13, 2009
    washer makes loud noise in spin cycle
  • Anonymous Mar 15, 2009
    Same problem here!
  • Anonymous Mar 14, 2014
    washer barely spins, makes loud noise
  • Anonymous Mar 26, 2014
    Washer tub dropped suddenly
  • Anonymous Mar 27, 2014
    clanking sound when you turn on the unit and the drumis not spinning on a front load washer
Bearings are bad need to replace
Posted on Mar 14, 2007
Maytag Neptune - MAH5500BWW makes loud, loud noise during spin cycle. What parts are necessary to repair the unit? I assume there are bearings and seals needed. Thank you.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washer is very loud during spin cycle. The machine is well balanced and does not rock
heatman101
Nov 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
In the final spin the washer is so loud you can't stand by it what is wrong with it
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Sep 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune
There is 2 possible problems. 1. Pump will make noise as soon as the drain and spin starts. 2. Rear bearing this noise usually starts later in cycle as the drum gets up to final speed. The rear bearing of coarse is the most expensive of the two as it is part of the outer tub.
Mar 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune makes loud drums like sound 5 min before it stops.
its probably because of the way the clothes are in it. you have to make sure the clothes arent leaning to one side and that they are evenly set up. otherwise when it goes into the spin cycle itll lean and hit the side of the washers inside and make it shake and do what you said it was doing.
Jun 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune bearing replacement
have a maytag neptune that makes an incredibly lound whinning noise in the final spin mode. Anyone experience this and what was the fix?
Jun 01, 2009 | Maytag Neptune MAH6500A Front Load Washer
Very loud noise during spin cycle
Probably a broken strut or support. some call it a shock absorber.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Loud noise
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
3,330 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
