Question about Braun Activator 8595 Electric Shaver
Braun 8595 vibrates excessively and sometimes jams
Motor is fine but drive components must be worn. Do you supply replacement parts?
  • 10 Answers
I'm in the process of replacing the Braun 8000 Series Activator Motor Drive Unit in my shaver. The Motor Drive Unit is all one piece, cost $33.99 at http://shaveroutlet.com/.To disassemble remove the plastic cover on the bottom that covers the cord socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I used my fingernail to create a space big enough to insert the corner on a credit card in the center of a long side and gently removed the cover. Using a screwdriver could damage the plastic. The two sides then pop off. There are a total of four screws holding the body together. Remove the screws, the shaver splits into. Remove the Motor Drive Unit and replace with new unit. There is also a circuit board with the batteries below the Motor Drive Unit. Assembly is the reverse of above.
Posted on Jun 13, 2009
I have the Braun 9595 and believe my motor/drive unit need to be replaced. I have read that even if I purchased the part myself, I would not be able to remove the old motor and install the new one as the...
DC motors usually do need to aligned to controllers however, with electric shavers they are usually sold together as a "drive unit." Now as far as your shaver goes, I could not find a replacement drive unit and what I did find showed that it was discontinued. Sorry. Braun 9595 5671 Pulsonic Parts
Nov 28, 2017 | Braun Activator 8595 Electric Shaver
I have had a Braun 8985 electric shaver for 4 years now. I have recently replaced the cutter block and foil but I am still having a problem with the shaver. It is not unusual for me to have to make 3 or...
The symptoms you describe indicate that the 'drive unit' is the problem. This part includes the swivel frame that the foils and cutters fit onto as well as the motor. Sometimes a piece of the plastic oscillator inside will break. The vibration causes the loud noise and it can not oscillate properly because of the break.
You will find the part needed at shaveroutlet.com. See link below for this part and scroll down the screen for helpful installation video
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
Jul 27, 2011 | Braun 8585 Electric Shaver
Excessive vibration with Braun razor
Most likely, the oscillator in the drive unit is broken. You will find this part for model 7680 at shaversource.com. See link below for product and helpful disassembly video
http://shaversource.com/shaver-replacement-parts/braun-7000-series-syncro-motor-drive-unit-p-110.html
Jun 09, 2011 | Braun Syncro 7680 Electric Shaver
My braun shaver does not run although the battery is good.
You can buy the motor drive unit here: http://www.electricshaverstore.com/get_item_7030621_braun-motor-drive-assembly-pulsonic-5671-790cc-959.htm but it needs to be calibrated to the circuit board according to everything I have read. Unfortunately, I do not know the procedure for the calibration.
Jun 27, 2010 | Braun 9595CC Electric Shaver
Long hair trimmer wont push down
the switch/trimmer is broken inside and will need replaced. You will find the replacement item for model 8595 at shaveroutlet.com. see link below
http://shaveroutlet.com/braun-8995-8595-and-8795-body-housing-with-trimmer-p-684.html
May 20, 2010 | Braun Activator 8595 Electric Shaver
Just replaced motor assembly now always shows liquid in cleaning station empty even with new cartrige
The motor assembly and the fluid level indicators are completely independent components and any coincidence between the timing of the problem with the cleaning base and your repair of the motor unit is likely pure coincidence. More likely, the cleaning base is at fault and will need replaced.
May 06, 2010 | Braun Activator 8595 Electric Shaver
The on/off slider is stuck on won't slide to off position
The trimmer/switch is broken. You will need to replace it. You will find the components that you require at shaveroutlet.com. See link below
To replace the part you will need to remove the 'cap' that surrounds the cord hole on the bottom of the shaver by gently prying it off with a small flat screwdriver or similar object. Once removed, the side grips will easily pull off revealing 4 screws. Remove screws to seperate the front and back case. The inner parts simply lift out and you can put them into the new case
Mar 22, 2010 | Braun Activator 8595 Electric Shaver
Cannot switch from '1' to '2' to '3'
The problem is that the switch assembly is broken. You will need to replace it. It comes with the whole outer case of the shaver and is available at shaveroutlet.com. See link below.
Yo replace it, you will need to first remove the 'cap' on the bottom of the shaver. This is a piece of plastic that surround the hole on the bottom of the shaver where the cord plugs in. Gently pry it off with a small flat screwdriver or similar object. Once removed, the side grips will simply pull off revealing 4 screws on the back. Remove screws to remove the back cover. Then list out the internal components.
Reassemble in reverse order
Feb 15, 2010 | Braun Activator 8595 Electric Shaver
BRAUN 8595 screen indicates i should change my foil and block
there is a reset button directly underneath the LCD screen
Dec 02, 2008 | Braun Activator 8595 Electric Shaver
Braun Activator 8595 Electric Shaver Logo
487 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
