Question about Hotpoint RGB790SEHSA Gas Kitchen Range
I CAN NOT FIND THE NON- SELF CLEAN MODELS FOR MY HOTPOINT GAS RAN
I am tiring to change my Hotpoint gas range from natural gas to lp propane gas
    President:
  • Hotpoint Master
  • 2,651 Answers
Heres the cpnversion kit number for the model that you listed, if you have a different model number then rgb790ssehsa, then please list it , and ill find you the correct part number
Posted on Nov 25, 2008
Change sunstar eup83 m natural gas to lp
did you change from gas to Ip .what is the problem?
Anyway if you have some trouble get support ONLINE chat from Hotpoint for you requirements.
God bless you
Oct 03, 2012 | Hotpoint RGB528 Gas Kitchen Range
I need to change the stove to operate on propane instead of natural gas.
You will need to conact a gas safe engineer who will change your gas jets from natural gas to LPG, then carry out various test to makesure your flueless appliance burns the gas safely and efficiently
Jul 11, 2011 | Hotpoint Kitchen Ranges
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Converting broiler in oven from natural gas to lp gas on hotpoint gas range
On the oven portion you will need to turn the oriface clockwise all the way till it bottoms out. This is the conversion from natural gas to lp gas on all gas ovens. Also make sure the valve down toward the back has been flipped off of nat. to lp. Good luck
Mar 02, 2010 | Hotpoint RGB745 Gas Kitchen Range
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
Flames in oven are WAY too high! Having trouble lowering them.
Hi! melisrus
If you are using LP, even if you change the regulator settings from Natural Gas to LP Gas, the orifices all need to be changed. The Orifices should have come with the new unit, if not contact Hotpoint.
www.hotpoint.com
Make sure you order the instruruction manual and this is an Oven with Range Top, you will need orifices for all the burners on the range top.
InMrFixIt
Nov 18, 2008 | Kitchen Ranges
Change Natural Gas Model of rinnai Heater to LP model
You can change the dip switches, but you may also need to work on the gas valve
Nov 12, 2008 | Hotpoint RGB528 Gas Kitchen Range
Hotpoint RGB790SEHSA Gas Kitchen Range Logo
74 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
