Question about Philips 42PF7320A 42 in. Plasma HDTV
30-45 min into use the picture goes black
Hello, unit turns on fine and works great for about 30-45 min. After that time the screen will go black and not have picture but will have sounds. Any ideas?
  • jellyfishpro Dec 27, 2008
    it is out of warrenty.. so that won't work...
  • 146 Answers
Sounds like something may be broken try calling the place where you bought and if the warrenty is still in effect you can get a replacement
Posted on Nov 25, 2008
I can turn on the tv and it's fine for about 20 min then the screen goes black with sound. I turn it off for a minute and it's fine for another 20 min. Like it's overheating.
It might also be a bad solder connection, short of checking voltages what I have done in this type of situation is with back off use a small fairly high speed fan - a hair dryer set to cool works, to cool areas of the boards inside to localize which board is causing this, with the set in failure, got it? it goes out cool it with a handheld hair dryer with air set to cool, when you find the spot where the problem is it will either instantly come back or try to.
Do it a few times to confirm which board is bad and locate a replacement board and swap it out.
Dec 15, 2012 | Proscan 47LB45H 47 in. LCD TV
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
Kds K-92bw After about 5 min the screen goes blank..turning the unit off than back on the screen looks great for a while about 3 min than goes black..seems to be a caused by heat
This issue is most likely caused by a capasitor doing bad. There is no easy fix. It must be disembled and the power supply repaired. If done properly, it should cost somewhere between $ 50 to $125. But it may do it again as the Pwoer supply is a known issue for this monitor. Sorry.
Sep 21, 2011 | KDS K717s 17" LCD Monitor
My 17 yr old sony triniton goes on after about 5 or so min. the picture is great then the screen goes black (audio fine) for about 4 seconds then the pic is back for about five min then the same thing...
U have a soldering iron,a roll of solder and can do a basic soldering work too?Yes,take the tv aparts.Tv have a cold sodering video board,that the board where it is connected to the CRT-(tv tube).Resoldering the sock pins of the video board that connected to the tv CRT-(tv tube).The tv picture,will be stable and work again as soldering work it is done and the tv have to a good connections between the tv video board and connected to the CRT-(tv tube) again.
May 24, 2011 | Sony Televison & Video
Black screen on XDA Orbit
when the screen goes black, ''restarted'' - do you restart the phone or does the xda restart automaticly?
thinkin whether its a battery/power issue..
Nov 21, 2009 | O2 Xda Orbit Smartphone
Toshiba 60 in projection tv picture goes out. the screen is black. unplugged until red light goes out, then restarted and picture comes back fine. until it happens again. 3 times in about 15 min. it...
the unit is developing whats called a "cold solder joint"...have it resoldered before it becomes a burnt out section of printed circuit board if it starts to arc...
Jul 25, 2009 | Televison & Video
Problem with Picture and sound after about 40 mins playing time.
the unit is over heating. Make sure you hear the fan come on. Also make sure the unit is in a spot where it gets ventilation. They get real hot and need to disapate heat or the mother board burns out.
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Philips 42PF7320A 42 in. Plasma HDTV Logo
122 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
