Question about Maytag MER5775Q Electric Kitchen Range
Proper Oven Temp
I have a model MER5755QAW. I had a baker element blow ( I mean really blow!) and replaced it. After I replaced I still had a problem with the oven heating, the baker element was not coming on. I tested the replacement element and it is fine. So I thought it maybe the oven sensor; replaced it and still not working. Any suggestions??
  • ammzj Nov 29, 2008
    I have a sim problem. My oven won't heat at all, but everything even the broiler works. I've tried just about everything and still no luck here. I'm getting depsperate enough to call a repair man. If I learn anything I will post it.
  • kmrridge1 Jan 20, 2009
    same maytag model and bake element popped loudly and when I replaced the element it is still not working. My broiler will not come on either but my stove burners all work fine.
    Sergeant:
    Champion:
  • 338 Answers
You need to make sure you have voltage coming out of your control board. 120v out of the bake relay. (usually yellow wire) and check wiring in the back of the stove. But first reset the breaker.
Posted on Nov 25, 2008
Dcs oven wos130 wont reach set temperature on bake
Good afternoon Steve!
The answer may depend a bit on what you mean by 'stops heating'.
  • One interpretation could be 'the heating shuts off, and the oven goes back toward room temperature
  • The other would be that it heats up, but it heats to a certain temp and then stays there. it's just not as hot as it's supposed to be.
If it's the former, that sounds like something is overheating and an interlock is engaging because it's interpreted as 'I'm too hot where I shouldn't be, and I should shut off before I cause a fire. I'd leave that to a better trained service tech.
If it's the latter, then it'll depend on how low it is. If it's way low, then there's a couple possibilities:
  1. The heater element is defective, and even at the full current draw the oven can run, it can't get any hotter than that upper temp. This would mean replacing the element.
  2. The temperature sensor in the oven is defective or mis-mounted. There should be a temp sensor inside the oven cavity. if it's disconnected, or, say, bent out of place and much nearer the bake element then it should be, then the heat coming direct off of the element may be fooling it into thinking the oven is hotter than it really is. this could mean replacing the temp sensor, or just re-mounting it to proper position.
If it's just a bit low, then there could just be a calibration problem. If you look at the manual here
DCS WOS 127 Use And Care Manual Child Safety User Option you can see how to adjust the calibration up or down in temperature to, hopefully, match the oven thermometer you're trying to use as a check.
Hope this helps!
Good Luck
D
Nov 18, 2015 | DCS Wot-130 30" Wide Single Electric Wall...
I have a Maytag Electric Range model MER5755QAW. It was obvious that the heating element was bad, you could see the area where it had blown out. I have replaced the heating element, and the oven will...
Just went thru this with my GE/Hotpoint oven....the oven temp sensor removed from oven should measure about 2K ohms and vary when put in ice water and hot water...if it does then problem is control panel circuit board.My oven's board was listed at $300+ so I bought new range ($500+).
Oct 14, 2013 | Ovens
Have Maytag MER5755QAW range, the oven will not heat up, the display was working isn't now, i check both elements and temp sensor, all ok
The display control will need to be replaced. It may be cheaper to replace the unit since the control is so expensive. Here is a link to the part you need.
Keep me posted!
Jan 21, 2013 | Maytag MGR5880BDS Gas Kitchen Range
GE Tru Temp Oven (JBP26W Y1WW), the baker element will not heat when the broiler element does. I have tested the baker element and it works. It appears through wire testing that the control panel is...
In situations like this, you may be better off calling GE Service. If they offer you a service contract, as they have us on a number of appliances, it's well worth taking. In the end, it has ended up saving us money, especially if the control panel must be replaced.
Nov 18, 2017 | Kitchen Appliances - Others
I have an Amana model ptc153b50ae Air/Heating unit. It has stopped blowing heat and does not turn off. I have to unplug it from wall. What could be the problem?
To get proper heat, keep your temp setting at +5 degree than your temp and also mode in "heat "position. If still noheat, check your heating sensor for closed circuit by an OHMs metre.It it'swith RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
Jan 19, 2011 | Heating & Cooling
Blowing cold air when in heat mode Goodman model AR30-1
Jan 14, 2011 | Heating & Cooling
Maytag MER5755QAW Range and the oven will not Heat
You said the broiler element which is the top element is working fine what about the botom element, needto check it, i would say its probally bad, also before you do anything be safe and unplug unit completely before checking
Feb 18, 2010 | Kitchen Ranges
My Maytag Electric Range oven part will not heat over 200* ......
Unplug the range.
Open the oven door.
Remove the racks.
Remove the 2 screws holding the bake element to the rear wall of the range.
Carefully pull the element from the access holes in the rear wall.
Remove the wires from the element.
With your meter set for continuity, put one lead on each element end.
If you get a reading it is good.
If it is good. Replace the wires and reinstall the element.
Pull the range out from the wall.
Remove the rear panels.
Plug the range back in.
Set your meter for 220volts or more.
Careful now because you are working with live voltage.
Set the oven for bake.
Put a lead on each element terminal to check voltage.
If you have 220 volts at the element, unplug the range and unplug the temperature sensor.
Set your meter for ohms.
Check the 2 leads on the temp sensor.
If at room temp the sensor is 1050 - 1100 it is OK. If not replace it.
If the temp sensor checks out OK, replace the ERC
Mar 12, 2009 | Maytag MGR5880BDS Gas Kitchen Range
Oven won't reach proper temperature and hold
If the element glows its ok , if you have replaced the sensor with a new one it can only be the control board. in some cases you can adjust the temp. through the control , it should list directions to do so in the manual. Good luck
Dec 30, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Fan Oven cooks at high temp when on any setting
Sounds like main oven stat is faulty.
Is the stat sensor fixed properly inside the oven?
Could have been disturbed when element fitted
Please leave feed back.
Thanks
Nov 25, 2008 | Jenn-Air JJW8530C Expressions Collection...
Maytag MER5775Q Electric Kitchen Range Logo
199 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
