Question about Canon PIXMA MP150 All-In-One InkJet Printer
I am trying to print but small window comes up saying -Service Error 51000 cancel printing then turn the printer off and then back on. I do this several times but it is still not printing . Help
  • 89 Answers
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Posted on Nov 25, 2008
The printer will not cancel a print
cancel via printer options in windows.. and turn off the printer... turn it on again.. hopefully it will solve your problem
Mar 01, 2011 | Lexmark X7550 InkJet Printer
When I try to print, I am getting a ratcheting noise and when I open the printer on my computer it says on the line with the name of my document - 'error'. When I try to print agin, it won't go past the...
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 29, 2010 | HP PSC 2410 All-In-One InkJet Printer
Error 49 4CO2 Service Error on a HP Laser Jet Printer 5500 DTN
This is related to the JetDirect Card and the specific print job attempting to print. If JetDirect is 615 or lower slide out JetDirect card and power cycle printer once it comes up o.k power down and
slide JetDirect card back in once the printer is back up look on the display for processing job which may take 5 minutes but it is the offending job trying to print again as it is still in the print que. If you are quick enough you can hit cancel on the display panel to cancel the corrupt printjob and if you are successful then the other print jobs stacked behind it should start printing away with no problem. Hp blames the 49 error on a plethora of problems though mine are usually related to documents using different versions of Adobe and also PowerPoint printjobs that are excessively large as the print spooler cannot handle them but it is always a corrupt print job and once that is cleared no problem. Occasionaly replacing the JetDirect card is required to solve the issue. With the 620 Jetdirect card no need to remove it just unplug the network cable same procedure as above.
Oct 22, 2009 | HP LaserJet 5500dtn Color Printer
When trying to print it says
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults.Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
Aug 30, 2009 | HP LaserJet 3015 All-In-One Printer
Having problems deleting pending documents
Assuming you have a modern windows pc, You will need to manually stop the print service. Do this by running the command "net stop spooler" from the "run" line. Then go to "C:\WINDOWS\System32\spool\PRINTERS" and delete all the files from there. After these files are gone, start the spooler service again by running "net start spooler". You should be all set after that.
Jun 09, 2009 | Office Equipment & Supplies
Printer not printing
Got problem solved , a piece of paper was stuck inside which I removed .
Nov 25, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Cancel printing doesn't work
If you have tried a reboot then why don't you try a Soppler Refresh.
Click on Start> Run (and type Services.msc) Hot ok.
It should open services window up.
Then look for Print spooler> Double click on it> Under General amke sure startup type is selected as Automatic> Then down you shoul see a tab which says stop> Click Stop (Now a small windows popps up and closes) You will see Start Highlighted> Click start and stop will be higlighted> if applicable click on apply or ok and close all the windows and restart the computer.
Then go to Start> Control panel> Printers and faxes> and check to see if the icon say 0Ready> if yes right click on the icon and left lick on Properties and then in the bottom you will see a tab which says print test page> click and see if it prints a test page.
Then try printing any document.
Good Luck
Aug 20, 2008 | HP Officejet 5610 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
93 people viewed this question
old marine
old marine
