Question about Sony MDS-E10 Mini Disc Player
Sony MDS-E10 has been dropped. need schematics to solve problem.
Hi. I am a working musician. i use a Sony mini disc player (Sony MDS-E10) to play my backing tracks. i dropped it and cooked the transformer. My repair man ordered a new one from Sony & replaced it. however there is also a problem with the disc carriage which was undetectable untill he fixed the transformer. i love the machine & have spent a lot of money on repair so far. I need to find a copy of the schematics to give to my service guy so he can complete the repair. he has emailed Sony 2 times with no reply. can you please help me?
Nick W ;-)
  • 1 more comment
  • info881 Dec 03, 2008
    Thanks Dan. I have since found the supplier of sony manuals & they want $84 plus post, for a manual, for a product that is obsolete & for which parts may not be available for anyway. its ridiculous really... Sony after service should just email clients the manual on request (for out of date machines) so they can at least decide whether or not an item is repairable.
  • info881 Dec 14, 2008
    Hi Dan any luck with that manual for the mds-e10?
  • info881 Jan 28, 2009
    thanks for your time Dan.. i appreciate it...Nick
HI I HAVE A MDS E10 PART OF THE MAINS BOARD HAS BROKEN OFF BY THE VOLTAGE SELECTOR ,CAN YOU TELL ME WHERE TO BUY A NEW MAINS BOARD,OR EVEN SECOND HAND, THANKS MIKE.
Posted on Jan 27, 2009
  • 4,234 Answers
Your service shop would need to purchase the service manual (if available). The problem here is that without seeing the unit, I can;t tell you whether the optics are bad or the tracking head is bad or the loading mechanism is defective. None of those options are cheap. Let me look into this a bit and see what I can find. I will try to get you part numbers at least with costs.
Dan
Posted on Dec 02, 2008
  • ABRsvcs Dec 03, 2008
    I have the manual available to me and I'm looking into the most probable parts for you. Stay tuned. More to follow in a day or so.
    Dan
MDS-E10 failed to record
If you recorded a disc and then the deck saved it; then you cannot play it is probably a bad mechanism. When I buy old decks I check them by inserting and recording a disc then ejecting it. If it will then not play when reloaded the deck is bad. Often the decks say they are saving but are damaged and cannot so this is the only way to know for certain.
Jan 27, 2014 | Sony MDS-E12 Mini Disc Player
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
MDS-E10 will not eject disc
The lower end mechanism were full of problems after about a year of use. The unit needs to go to an appropriate Technician- NOT Sony as they will just replace the mechanism if they even work on it and it will be the same cost of a new unit. The mechanism you have needs lubrication and a limiting resistor placed in line with motor to not break plastic parts.
Jan 27, 2013 | Sony MDS-E10 Mini Disc Player
I am selling my Sony mds e-58 minidisc player and someone is asking me if it has long play function. Does anyone know if they do cause I don't. Thanks in advance.
No it doesn't.
You can download a free copy of the user manual here.
I hope that I've been of assistance, please don't forget to take a moment to rate my answer.
Feb 02, 2011 | Sony MDS-E10 Mini Disc Player
I have Sony md player/recorder,model is MDS-E10. it play correctly but the problem is at recording,once yuo put the recordable empty md and you comand it to record it do not record any thing why the source...
Minidisk systems encode music diffferently than CD's do. The instruction manual for your model can be found at http://www.minidisc.org/sony_mdse10_manual.pdf you will need to reference page 18 for instructions and trouble shooting.
May 06, 2010 | Sony MDS-E10 Mini Disc Player
Can a MDS JE330 play minidiscs recorded by a "hi md" player? most md-players can not.
No. Only Hi-MD players/recorders can play Hi-MD's. They're a later and totally different technical specification. The discs may look superficially similar but it's like trying to play a Blu-Ray disc on a CD player.
Apr 11, 2010 | Sony MDS-JE330 Mini Disc Player
Pitch control
No. You have pitch control on this model, but only by altering playback speed by plus or minus 12.5%.
Mar 03, 2010 | Sony MDS-E10 Mini Disc Player
I have a minidisc model mds e10
it seems your MD unit is expecting a digital signal on the digital input causing this message to appear.
You need to connect a signal source to the digital input
or
connect an analog signal to an analog input and select the analog input as signal source.
In both cases the DIN UNLOCK message will then disappear.
Cheers
May 14, 2009 | Sony MDS-E10 Mini Disc Player
MDS-E10 Problems loading and ejecting discs
Hi, its probably way too late to give this solution but there is a ribbon cable that runs from the main board onto the display board that causes this problem. Its very accessable from the top and all you have to do is pull it out clean the contacts and re-seat it. This will resolve all sorts of communications issues with the display and buttons.
Oct 26, 2008 | Sony MDS-E10 Mini Disc Player
Sony MDS-E10 Mini Disc Player Logo
292 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
