Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Micro wave not heating
All other functions ok, but will not heat.
  • 706 Answers
Hello jrsnelus,
The main purpose of a microwave oven is to generate microwaves to heat food in the compartment so if it doesn't do that, then chances are that a component has failed. The fact that everything else seems to work suggests that you at least have ac power getting to the controls. You more than likely have a bad magnetron tube , filament transformer or high voltage capacitor that failed as part of the microwave generating system and it is not something that the untrained person should attempt to fix. Even unplugged, the high voltage capacitor remains charged up sufficiently enough to cause serious injury to someone. I've always been an advocate of the good old saying that if the cost to repair exceeds the cost to replace...then simply replace it. Even if you get an appliance tech to examine it, chances are his fee and the components that he finds defective will more than offset a replacement appliance.. I wish I could have suggested a better alternative for you..
Regards,
Rick
Posted on Nov 25, 2008
MICRO DOES'NT HEAT
First, check to make sure that the door is closing and latching fully and that there is nothing jamming any of those mechanisms. There are safety devices that keep microwaves from turning on if they think the door is open/ajar.
If the door is fine and the rest of the functions (timer, etc.) are behaving, it's probably a busted magnetron. That's the part that actually emits the waves that do the heating. It's a part that can be replaced, but probably cheaper to get a new microwave.
Oct 02, 2012 | Sharp Microwave Ovens
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Micro wave stopped heating. All other features
Check the door safety interlock switches. Magnatrons are pretty tough but the little switches are not.
Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Micro is turning on ok and working but not heating up,what would cause that? light is on ok and plate is turning, just not heating
How old is your m wave? Sounds like you need to replace it .You can get a new one from Wal mart for under 75.00.and that will get you the big 1 sq.ft one..I once broke the plate in my m/wave and believe it or not they wanted more for the new plate than I paid for the M/wave BEFORE you do that check your power level settings perhaps it was turned down
Jan 28, 2010 | Sanyo EM-G2585W Microwave Oven
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
Boiling waer under micro wave lots of steam into micro wave, turn on micro wave ,pop noise like glass miro wave comes on louder hum than normal no heat
Q - The microwave display counts down and the inside light is on,  but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
 Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave makes a loud "hum or buzz" noise but will not heat up the food?
A - 9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
Mar 03, 2009 | Amana Radarange Microwave Oven
Microwave comes on but doesn't heat ge.jvm1540
In the case of microwave ovens, the commonly used radio wave frequency is roughly 2,500 megahertz (2.5 gigahertz). Radio waves in this frequency range have an interesting property: they are absorbed by water, fats and sugars. When they are absorbed they are converted directly into atomic motion -- heat
So, NO Micro waves NO heat......... Need to check for Microwave emitter device installed inside.
Sep 11, 2008 | Microwave Ovens
GE Over range microwave, JVM1660
This just happened to ours as well. Apparently the magnetron (device that creates radio waves that heat the food) is broken. I'm trying to pry the darn thing out of our kitchen now so I can replace the magnetron. Look for this part WB27X10489 on Google. I found it on ebay for $65. If it fixes the problem I'll post again.
Aug 18, 2007 | GE JVM1660 Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
61 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
