Problemes with the web cam of the hp pavillon dv 9000
My web cam not star, and the steps and instruction of the device manager not serviced, T hope find a solucion for thar, thanks. Fernando Zambrano P
Uninstall the software which you installed for the webcam..
And if possible remove the drivers related to the webcam from the DEVICE MANAGER..
Posted on Nov 25, 2008
Toshiba mini sattelite mini notebook NB305-N442BL webcam wont work
click start control panel view devices and printers you should see your web cam from there
if you are have trouble with your web cam
click start control panel administrative tools ,computer management ,device manager scroll down
image devices you could see a yellow question mark ? right click to reinstall drivers or
update driver
hope it helps
Jul 18, 2012 | Computers & Internet
When installing a Web-Cam make sure your old cam has been uninsulated.
When you set up a new Web-Cam for your computer go under to the computers Start up Key, click the "Computer" button, and you will see a option to pick from. Click "Control Panel" and a list of installed programs, and accessories installed in your computers memory will come up. Find your old Web-Cam under the installed "Device Manager" icon.
Uninstall your old cam, and make sure the New one IS NOT plugged in at this point. After you uninstall the old one, you can then PLUG in the new cam, go back to "Device Manager" and click on "View Hardware and Devices" and your computer should recognize you have new hardware plugged into one of your USB ports, and a balloon should pop up, and Click that ballon, your computer SHOULD read and install the Cam, if not use your "Device Manager" and IF a disk came with your Cam, put it into your computer at this point if you already havent. Your PC should recognize what you are tring to do, and install the Cam. Hope this helps, if not type Web Cam into the search engine in your computers search tab, while under the Device Manager, and it will tell you step by step on how to do lots of things.
on Feb 09, 2010 | Cameras
Just bought spz2000 web cam but instructions not clear in quick start fact there are no do i start the thing
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or update driver
also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service
hope this helps
Jun 13, 2011 | Computers & Internet
When I try to start my web cam I keep getting this message about web cam driver did not work restart camera or computer. I have restart my computer too many time and still does not work.
It sounds like you need to update your driver for the web cam.
Step 1: Go to device manager
Step2: Find the web cam in the device list
Step3: Open Properties
Step4: Have the device manager search for driver.
Other option:
with the web cam unplugged from computer, in device manager uninstall the web cam, restart computer, then plug web cam into computer and let OS find and install drivers.
Mar 05, 2011 | Computers & Internet
I cont view my web cam
Make sure it is enabled in the Device Manager. Depending on your version of windows it shoud be under computer properties. Do a google search on how to enable your webcam in device manager. There should be many step by step tutorials for you to browse. Hope that helps.
Jan 14, 2011 | Acer Crystal Eye webcam
Have Web Cam pluged in. Still nothing camera not functioning. I have an Emachine loaded with Windows Xp. Need step by step instructions on what to do now. Do not have cd to load software.
Follow this link and click on download. Click on run when the popup box comes up, follow all of the prompts and you will have your drivers downloaded. When installing your drivers, make sure that your cam is hooked up. Hope this helps!
Oct 11, 2010 | Ezonics EZCam Webcam
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
Web cam do not turn on for pavilion dv6910
There are two files needed for the webcam to work. Go to the HP support driver page and look for the driver for the Cyberlink Youcam. You'll have to put the exact model number in a special search box in order to download the youcam software from HP
Sep 18, 2009 | HP Pavilion DV6910US Laptop
I don't know what kind of cam I have?
1. Connect your web cam
  • Attach all power cords (e.g. laptop and/or web cam).
  • Plug your USB cam directly into your computer (do not use any external USB hubs). Turn your cam on
  • As long as your web cam and computer hardware are working, Windows should detect it!
2. Open Device Manager
  • For Vista
    => Click Control Panel. If you have Control Panel Classic View, click Device Manager
    => Click Control Panel. If you have Control Panel Home View, click System and Maintenance->Device Manager
  • For XP
    => Click Control Panel->System, then Hardware tab, then Device Manager button
3. Find your web cam in Device Manager
  • Understanding Device Names
    => Windows provides user-friendly device names to accomodate us humans. As far as Windows is concerned, the device name is simply a comment!
    => It's those cryptic Device Identification strings that really identify a device
    => Device Manager displays whatever device name it happens to find in the device driver
    ...==> If Windows finds NO device driver, your web cam may be named “Unknown” or "Other" device
    ...==> If Windows finds the WRONG device driver you may see your web cam with the WRONG device name
  • How to find your web cam
    => While your web cam is connected, look through all of Device Manager for devices with a yellow icon (probably a yellow question mark)
    => Look if a device category Other Devices. Also, be certain to expand the USB category to check all devices listed under it
    => Your web cam will appear as a device with a yellow icon (probably a question mark)
    => Click on thumbnail to see the full sized image
    How to verify the device you found is your web cam
    => Your web cam device will only appear in Device Manager when the web cam is powered on and connected
    => Disconnect your web cam. Verify the device you had found is no longer displayed in Device Manager
4. Find your web cam's Hardware Ids
  • In Device Manager, select your web cam device, rt click Properties. Click Details tab
  • Select Hardware Ids from the pull-down. You'll see a list of one or more Hardware Id strings
Aug 08, 2009 | Computers & Internet
HP webcam dv6000 is not working properly
Weird but worked for me for yahoo and messenger but not quickplay. If you have the Chicony web camera, follow these steps to download Acer webcam drivers.
1. Download Acer 5210 Chicony Webcam drivers.
2. Run the setup file.
3. Follow installer prompts then RESTART PC.
4. Ignore the 'installing drivers' popup.
5. Open up the Control Panel.
6. Open up the Device Manager.
7. Select webcam from 'Imaging Devices'.
8. Right click on webcam and select 'Update'.
9. Select 'Browse computer for driver'.
10. Choose 'Let me pick from list of devices on PC'.
11. Uncheck 'Show compatible hardware' checkbox.
12. Scroll down to Chicony manufacturer.
13. Choose the 'Acer Crystal Eye Webcam'.
14. Install even if a question pops up.
Thanks to DylanBennett for uncovering this odd fix for the HP webcam
Oct 14, 2007 | Computers & Internet
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
