Question about Motorola Mobility HS850 Consumer Headset
Headset no longer working
When I open the boom on the headset , the phone shows that it is connected but you can not hear anything through the headset. When you close the boom, you hear the beep on the phone stating that is disconnected. The blue blinking light seems to be weak when supposedly connecting to a number but otherwise the blue light is strong. Any suggestions?
It worked!!! Mike.
Posted on Jun 11, 2007
You need to remove the device from the phone directory. Turn off the phone and the device. Wait about a minute then turn on your phone. After the phone is ready for use, turn on your bluetooth and proceed to pair the device with your phone. The phone should recognize the bluetooth and you'll be able to add it once again to your list of blue tooth devices.
Posted on Jan 20, 2007
H730 i cant hear anything
Try unpairing the phone and the Bluetooth headset. Also ensure that you always have the boom on your headset open while trying to use it. The Boom is the on/off switch.
Mark
Motorola Support
Jul 23, 2014 | Motorola Mobility H730 Bluetooth Headset
Plantronics Noise Cancelling headset H261N hearing others problem
where is the other end of your amplifier connected? To a computer, to a phone?
Did you connect correctly the mircophone to your amplifier and from your amplifier to the correct plug?
Oct 20, 2007 | Plantronics (43-1960) Headphones
Bluetooth connection problem
Depending on the phone... try andremove the current bluetooth device. Close theheadset. Go to the phone and choose discover, or search. Open the headset and pressand hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
If this doesnt work: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
Jul 27, 2009 | Motorola Mobility H700 Wireless Headset
I have a blackberry storm and im trying to pair my bluetooth h700 with it. it found the headset but it keeps saying connection successful the 2 seconds later itll say connection terminated. all my...
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
Jan 18, 2009 | Motorola Mobility H700 Wireless Headset
H-700 motorolla bluetooth
1. Bluetooth enabled?
Dec 19, 2008 | Motorola Mobility H500 Wireless Headset
Motorola h350 blue tooth headset microphone does not work
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
May 30, 2008 | Motorola Mobility Bluetooth Headset H3...
Motorola H700 Bluetooth connection problem
4.Select H700 once a connection is detected.
Tips:
Apr 01, 2008 | Motorola Mobility Bluetooth...
I have no idea how to work my headset
I was having the same problem with my phone. First close the boom on your headset and hold the call button until the light turns purple. This will reset the headset and prepare it to pair up again. Once that is complete try pairing it back with your phone. If it still does not work, you might have to manually connect to the bluetooth headset from there. Go into your trusted devices on your phone. Select the bluetooth device, select connect. Hopefully that works. If not try calling 1-877-motoblu and ask for customer service and see if they can walk you through any other solutions.
Nov 17, 2007 | Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
Place the unit headset back in pairing mode by holding the call button for 1 to 5 seconds until the light turns purple. Then open the boom. Then try to reconnect .
Apr 19, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility HS850 Consumer Headset Logo
79 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
