Question about Maytag MGR5751AD Gas Kitchen Range
Digital button won't turn on my oven
I tried to turn my oven on, you have to press bake and then press another digital button to make the deg. work. nothing is working and I need the oven by Wed. not sure if it's a circuit problem or fuse.
    Sergeant:
    Champion:
  • 338 Answers
Sounds like either the control or touch pad
Posted on Nov 25, 2008
I cleaned the oven self clean, now the oven preheat feature won't turn on
I don't know what kind of range you have or if it is gas or electric. You may have to call a repairman.
May 25, 2015 | Kitchen Ranges
Oven won't start
Try pushing the "convection oven" or "bake" button first, then enter the temperature you want. Then "Start".
Sep 24, 2012 | Thermador SC272T Electric Double Oven
CANNOT FIGURE OUT HOW TO CALIBRATE THE OVEN. OVEN TEMPERATURE IS OFF 50 DEGREES. INSTALLED A NEW THERMACOUPLE. THIS DID NOT HELP THE PEOBLEM. OVEN WAS PURCHASED IN 1992. THANK YOU FOR YOUR HELP.
Without the Model Number I can only give you Basic instruction.
If your machine is Digital the best way to calibrate if find the manuel of your machine useing your Model number.
Some of the digital models : select bake and press and hold the up or down Temp button for 5 Sec to enter the calibration mode.
Some models require you do get the temp to over 400 deg befor you can enter the Calibration mode.
If your machine has a turn knob ... Take the knob off and see if there is a small screw in the center... This is the calibration screw.
Oct 05, 2010 | Magic Chef 9122 Gas Single Oven
Rf367lxss oven temp low need to adjust rca whirlpool
MOST OVENS ARE ADJUSTABLE TURN ON BAKE, ADJUST TEMP ALL THE WAY UP AS HOT AS IT GOES, HOLD BAKE BUTTON DOWN UNTIL IT BEEPS AND REGISTERS 0. THEN ADJUST TEMP UP IN 5 DEG INCREMENTS.GOOD LUCK!
ERIC
Jan 21, 2010 | Whirlpool Ovens
GE Gas built in oven Model JRS14 will not heat up
The bake ignitor has failed.Turn off the gas supply. Remove the racks. Then remove the bottom pan cover in the oven to access the ignitor. Place a amp meter on one wire of the ignitor.Turn the BAKE switch on. If it reads less than 3 amps,replace the ignitor.
Oct 30, 2009 | GE 24" Built-In Single Gas Wall Oven
Digital oven will not turn on, I press bake/broil it reads ''Loc''
Look on the control panel for an icon that looks like a padlock near one of the buttons. Hold that button down until it beeps and that should unlock the panel.
Mar 20, 2009 | Ovens
Bake button doesn't work even after ignitor replaced
While unlikely, the ignitor in theory could have damaged the ERC (main oven control) it is more likely you have a bad keypad. Try pressing and holding bake and broil pads at the same time for 5 seconds and see if the display shows SF (will look like 5F). If it does, press the start button and try again bake again
Dec 02, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Self clean
if your oven has a clean cycle it will say clean on the knobs or a button if digital.self cleaning cycle turns on both broiler and bake elements and temperatures up to 1500 deg.and disintegrates everything in oven also you will have a door lock on oven door
Nov 25, 2007 | Kitchen Ranges
Maytag MGR5751AD Gas Kitchen Range Logo
109 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
