Question about Water Pik & Wallmount Showerhead
Hi there!! Just a month ago i bought a waterpik hydropulser dentaire sans Fil, from my dentist..the box says" no warranty"..yesterday when i was about to use it, i noticed that the unit was not working anymore..It has power but water didnt come out when i press the button.. Is there any help..or at least a customer service here in the Philippines who could provide us assistance.??? Thank you.. U can reach me at this email: bethnavarro7@yahoo.com
I have a Samsung laptop model NP350E7C-A05UK bought less than 8 months ago. Yesterday it developed some flickers on part of the screen. When playing video these appear like blurred rectangles of many...
Hi there, first of all you can try to install original drivers you've have received with your NPC. Then try again....If this doesnt help and your unit is in warranty I can advise you to contact local service as there could be a hadrware problem with graphic card od lcd. Cheers
Oct 08, 2013 | Samsung Computers & Internet
The pump is working fine for a couple of months, I did many water bottle changes without any problem. Yesterday I changed a water bottle and the pump is not sending water, what can I do? how long the...
look on the box or inside the box or pack it came in for warranty cover. If you cannot find it call the store where you bought it or the manufacturer. If they cannot help buy another one. Everything is made not to last these days.
Aug 18, 2013 | Bunn FloJet BW1000 bottled water...
Je dois installer un clavier sans fil avec souris sans fil KB600;Impossible de trouver le site geniusnet.com pour suivre les indications données .....
Connect le recepteur dans une sortie USB; met une paire d'accumulateurs dans le recepteur est l'autre dans ou dans un autre chargeur et attend une journee qu'il soit pleinement chargees puis met le dans le souris.
Elimine le vieux PS2 kit, arrete et restart le pc et: tape sur quelques lettres sur le clavier; bouge le souris et presse le bouton sur le recepteur - si le couplage est fait un LED s'allumera.
Oct 06, 2010 | Computers & Internet
My 52inch xbr4 tv is 2 years old. Intermitently over past 2 months, when I first turned it on, I get thin vertical lines and double imaging especially over left half of screen. After a few minutes it would...
I have the same issue. Bought the TV 1/08 and it started showing those exact symptoms about 3-4 months ago. It generally progresses and gets worse. You can try to fix it as it's some kind of TAB connector issue, or keep calling Sony so that the 52" owners of the XBR4 and 5 series get the extended warranty just like the 46" owners received for the same series. If enough of us keep calling, they'll have to act.
Jan 18, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
J'ai installé un routeur il me mentionne que l'installation est complété mais lorsque je débranche le fil qui va au PC, ca ne fonctionne ps sans fil.
Retournez dans la configuration et vérifiez s'il n'y a pas un champ à cocher pour activer l'option sans-fil.
Sep 07, 2008 | Computers & Internet
Missing dll since XP sp3 has been installed
It means : SP3 introduced a new wireless lan application programming interface (windows program that interacts with your wireless card/device driver)
solution : check your wireless device or computer manufacturer for updated (works with SP3) driver.
Aug 28, 2008 | D-Link AirPlus DI-524 Wireless Router
2001 Kia Rio Engine Cranks, Won't Fire, Reoccuring
i am having the same problem, thought it was ful pump, no go, I heard they had problms with the fuse box and wiring harness, my mechanic messed with mine a few days ago and it has not did it since, but I am looking at changing that. GL
Aug 01, 2008 | 2001 Kia Rio
Water Pik & Wallmount Showerhead  Logo
50 people viewed this question
Top Water Pik Home Experts
john h
Are you a Water Pik Home Expert? Answer questions, earn points and help others
