Question about Kenmore Washing Machines
Wahing machine will adjitate only
It worked earlyer today, but now it will not rinse or drain.
When the dial is put on rinse or spin then nothing happens. but when ever I put it on wash or rinse it will adjitate but that is all it will do.
    Sergeant:
    Champion:
  • 324 Answers
Check your lid switch and check your cold water inlet
Posted on Nov 25, 2008
Model 23832100
Sounds like clutch not catching,this may need to bed in .The fact it works okay with no load and no spin with load sounds like clutch/ but also could be motor torque.Ask repair man to recheck work done.
Jan 14, 2014 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series wahing machine wont start rinse cycle
Have you tried the rinse cycle in every wash cycle selection on the dial. Some times after using one particular dial setting all the time the contacts on the switch get corroded or burnt out, if the rinse cycle works in other settings on the dial then this is most likely the problem. You can then look up on line and order a new switch for the unit usually takes about two weeks to get in and is fairly easy to replace.
Aug 26, 2012 | Whirlpool Washing Machines
Bought used roper washer. worked for first load and now wont work. washes and then the dial satys in same place. Wont empty or spin, nothing.
Hello, Thank You for using FixYa. I will be helping you today. If the unit fills and agitates but wont spin or drain the yourlid switch is bad..Here is a link to order the part and a how to video
http://www.repairclinic.com/PartDetail/Lid-Switch-Assembly/3949247/547225
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Roper RAS8445KQ Top Load Washer
Control dial moves along fine but drain,spin, rinse never happen
replace the water pump. about 46 dollars and a 20 minute job.
Jun 24, 2009 | Maytag Washing Machines
Will agitate; but won't go into rinse or spin - even if place the
If it will not spin/drain/advance timer or make any noise when you set it to do these options your problem is the lid switch. Your washer thinks the lid is up so it wont run as a saftey measure. You can order and install this item and its pretty easy and very common.
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
Bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Nov 22, 2008 | Bosch Exxcel WFO 2264 Front Load Washer
Whirlpool gold UIltimate care heavy duty super capacity washer
Well you can check the capacitor with a meter for farads, but it sounds like you have a clutch and/ or gearcase failure causing the motor to overheat. The second thing to do is unplug the washer and check the timer. I would right after the agitation to inspect for heat and burnt connections.
Oct 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
Apr 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool filling and washing, not draining, rinsing or spinning
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
Apr 01, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
95 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
