Question about iLO MP3 Player
Computer reads MP3 but won't install MTP device..so MP3 dont work
My computer will read my MP3 player, but only until I have to try and install the MTP device. I've got a Creative Zen Plus. It worked fine in my old computer and my mom's laptop. But since I got a new computer I haven't been able to fix the problem or be able to download the thing needed for my MP3...anyone help?? Please??
  • 3 more comments
  • Anonymous Nov 29, 2008
    mines a sansa fuze and ever since i restored my os my player wont even charge
  • Anonymous Dec 06, 2008
    yeah m8 same problem for me, my computer won't install any MTP devices and apparently theres nobody who knows a solution :(
  • Ults Dec 24, 2008
    i have got the same problem with my brand new Creative Zen Mozaic, my zen stone works fine, it says it can't install the MTP device....
  • zeagler606 Mar 27, 2009
    I have a Creative Zen V that worked fine with my computer for almost a year. About 2 months ago Media Player stopped recognizing it which means I can't put any new files on it!! It is being shown in device manager, but with an exclamation mark. I try to update it thru device manager and also when "new hardware found" screen pops up, but the computer says this MTP service is not installed. I have contacted Creative and eMachine about the problem. Have tried several things, like uninstalling the Zen, updating Media Player, doing a system restore, etc. I've read something about changing the registry but hesitant to try.
  • Anonymous Apr 05, 2009
    i have the same problem with my zen
Same type of problem i used to work does not work at all now a my mate wants to put some things on it
Posted on Dec 01, 2009
I need driver called mtp usb device for my c2-03 mobile
Many devices use Microsoft's Media Transfer Protocol to synchronize with computers. Unlike standard USB mass storage devices, MTP devices don't behave like USB flash drives. Windows Media Player includes built-in support for MTP devices and can synchronize media files to and from them. You can download MP3s to your portable music player, cellphone or other MTP device using Windows Media Player's sync feature. The device appears in Windows Media Player when you connect it to your computer.
Read more: How to Download a MP3 to MTP ' eHow.com http://www.ehow.com/how_12186594_download-mp3-mtp.html#ixzz1wFmzrcvt
May 29, 2012 | Nokia C203
Computer (Windows XP) does not recognize the Coby MP-C7085 player
On the MP3 player, go to settings > system, put the USB mode to MSC, then reconnect to the computer, computer will read, the device is currently on MTP and your computer doesnt have driver so that is why its not recognizing.
Aug 29, 2011 | Coby MP-C7085 MP3 Player
Hi, my pc don't read the mp34 audio player =( help!!!
Why is my mp3 and mp4 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see mp3 and mp4 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the mp3 and mp4 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: mp3 and mp4 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 and mp4 Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for mp3 and mp4 Players when used with Windows OS.
The mp3 and mp4 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
May 05, 2011 | Digital Audio NAP256 MP3 Player
Computer not reading
check to see if the media player has syncronization functions working and update drivers for MTP device as well as the media player. Check to make sure the hardware add indicates proper detection and not a yellow ? because it is only recognizing its usb.
Aug 24, 2009 | SanDisk Sansa m250 MP3 Player
My creative zen stone plus mp3 isnt recognised when connected by a usb to the pc
first install all the drivers and software that came on the cd with the device. if the installation procedure asks to connect the device, connect it, if not, wait with connecting until after the install is complete and after you have rebooted the computer...
Jun 22, 2009 | Creative Labs Zen Stone Plus MP3 Player
My GPX mp3 player says MTP?
MTP stands for Media Transfer Protocol. If you did not run your installation CD BEFORE plugging the mp3 player into the computer, Windows XP and higher will read it as an MTP Device. As long as the player does not cause you problems, there is nothing wrong with your computer calling it that. If this is a problem: unplug the mp3 player from the computer, uninstall all software for that player, restart computer, reinstall allsoftware from installation CD, restart computer, then plug mp3 player into computer. Good luck!
-Tha Mp3 Doctor
Jan 05, 2009 | GPX MW-238B MP3 Player
I have a Gigaware 4GB MP3 GX400 4-420
Download the drivers from Creative Labs, or with the disk included with the MP3 player.
Dec 27, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen vision m not recognized
Same problem. Solved by downgrading Windows Media Player to v.10. Do it through Control Panel and click Remove WMP11 and WMP11 runtime. Restart, connect your player and if not recognized do go to Control Panel=>System=>Hardware tab=>Devices. Find Portable Devices drivers in the menu and click Uninstall MTP device. If still not detected, go to Control Panel=>Detect New Hardware and run that. The player should connect automatically. WMP 11 has a glitch that disallows 3rd party MTP players. Intentional or purposeful? Ask B. Gates.
Jul 22, 2008 | Creative Labs Zen Vision Digital Media...
1,093 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
