Question about Texas Instruments TI-83 Plus Calculator
Ti 83 I have changed the batteries and the main battery but my calculator still will not stay on the screen turns black then turns off. help
Remove one of the AAA batteries. Press and hold CLEAR while reinstalling the AAA battery. Continue holding CLEAR button and press ON. Release buttons and press CLEAR again.
Posted on Mar 18, 2007
I have the exact same problem. Screen is just black, and you can do NOTHING! My precious Ti 83! Help!
Posted on Feb 09, 2007
My ti-83 wont turn on. I changed all the batteries including the back up. Before i changed the back up i put in 4 new AAA batteries and then the screen went black. I tried adjusting the contrast but it...
I am sorry that I could not respond earlier. I am not sure of this but I think you can remove the back up battery and also the main battery, check the cells to see if there was a drain on the new cells , if so there is a short in the unit. If not keep aside for few hours and then replace the back up and then the main cells.
If there is no display there is some issue on the motherboard and might need a consensus.
Oct 26, 2011 | Texas Instruments TI-83 Plus Calculator
I have had my ti 83 plus since fall 2005. recently the calculator has informed me to change the batteries. So i replace the backup battery and the main batteries. now it wont even turn on. Help.
The screen may be too dim to read. Try pressing 2ND->Up arrow key repeatedly while the calculator is turned on and it may darken the screen enough so you can read it.
Feb 14, 2011 | Texas Instruments TI-83 Plus Calculator
I haven't used my TI-83 Plus in a few years and now i need it. I changed the batteries and tried to turn it on. It won't turn on. I'm thinking maybe I need to change the back-up battery?
The backup battery is only to retain the contents of memory while you change the main batteries. It does not affect the operation of the calculator in any other way.
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we can go on from there.
Jan 29, 2011 | Texas Instruments TI-83 Plus Calculator
I changed batteries and now the screen is black. How do I fix it?
Hello, it sounds like your contrast needs adjusting. Turn your calculator on; press the "2nd" key and down. The contrast should adjust.
Happy calculating
Jul 31, 2010 | Texas Instruments TI-83 Plus Calculator
I replaced the batteries on my TI-83 and now the screen is black
Reduce the contrast.
1. Press [2nd] key and release it
2. Press [DownArrow] and release it
3. Repeat steps 1 and 2 in sequence until screen lightens to your taste.
Hope it helps.
Sep 23, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 screen is black
The "color" on your screen reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly.
Aug 29, 2009 | Texas Instruments TI-83 Plus Calculator
My TI 83 + won't turn on
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on at all. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Feb 24, 2009 | Texas Instruments TI-83 Plus Calculator
TI 83 Plus won't turn on after battery change
I was having the same problem...I found the info below on another blog and it helped me fix my calculator problem. Take out all the batteries, hold the DEL button and put the batteries back in (keep holding the DEL button until all batteries are put back in). This will restart the calculator and restore it to its default settings...but it makes it work again!
"Reflashing the OS is probably the thing to do now. I think there's some trick that throws the calc into OS receiving mode. Hold down DEL while putting the batteries in? I don't remember if that's it. Go to 1-800-TI-CARES/ti-cares@ti.com if you need specifics on getting the calc to take an OS upload given the state it's in."
Ti 83 plus small black screen?
try pressing 2nd then hold in down arrow to change the contrast
Feb 14, 2009 | Texas Instruments TI-83 Plus Calculator
Help
You should press the 2nd and then hold the down arrow to cahnge the contrast. If that doesn't work then you should try resetting the calculator by taking both the back up and main batteries for 45 seconds.
Jan 16, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
936 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
