Westinghouse Front Load washing machine LF711C will run for a couple of mins then flash "SE" on the screen. Will not work. Cant find any ref to SE in the troubleshooting section on the manual. Please help.
  • 706 Answers
Hi Farken,
The problem is due to a sensor, which is placed on the rear end of the electrical motor. It senses the direction the motor turns. Just replace the sensor(just one little screw and a connector to disconnect). Or if you can get your hands on a second hand motor replace it completely.(might be cheaper.
Regards,
Rick
Posted on Nov 25, 2008
My washer wont rinse or spin SE keeps coming on
Hello
LG washing machine error code SE indicates a "motor fault.
You can try resetting it by unpluging the unit for 3 min and see if it clears.
If not, it s going to need service.
Apr 08, 2011 | LG WM-12230FB Front Load Washer
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Stops mid cycle. Light flashes, cant get it to move on so have to start all over again
Hi there.
I have the same problem with my machine. Whatever program I select, the machine runs fine until it reaches 54 mins of the cycle remaining. To overcome the problem just to select a cycle that will not stop mid cycle, select a program which is less than 54 mins. I think the 40 degrees and quick wash select is the one to run with. The cycle is 45 mins, obviously less that 54 mins. The LED timer will display the cycle time. No problems with this cycle whatsoever. Not the total solution, but at least you're able to complete a cycle. After it's completed, I also run the spin program at 1200rpm. I hope this helps.
Regards, Ian.
Nov 22, 2010 | AEG Lavamat 72640 Front Load Washer
How do you clean the mould build up off the flexible door seal of a front loading machine. Can I take out the door seal safely to do it. Westinghouse front loading washing machine model LF711C
Bleach:Water solution 1:2 should kill the mould effectively.
What they should have told you when you bought this machine and what it almost certainly says in the owners manual is that front-loading washing machines, all brands, are prone to this problem. You must wipe the rubber gasket/door seal off when done using. Every time.
Dumb, I know, but necessary.
Sep 08, 2009 | Washing Machines
When washing stops and flashes f20
That code means "No water or Insufficient water supply" Check the water supply valve, the fill hose screen for debris... Good luck let me know if that solved it..
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Samsung b1245s washing machine
The error code HE2= water heater error (The heater element did not getting hot)
Unplug the machine to reset this error.
Try different cycle let see you still getting the same error.
May 07, 2008 | Samsung WF337AA Front Load Washer
40C cycle stopped with 12 mins on display - now nothing works
Press "end of cycle" & wait for 2 minutes then try the door, do not force the door........................ If problem persists go to your model above & click on your model number & look for solutions....should find something.
Jan 12, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Westinghouse 798 front loader 7kg washing machine
God Sir
I am mr Yapi Antione from abidjan i am dealing with all washing marshing i saw your profle and i am intrested to to know the pris list of all the marshing in your company
i will like to haer from you as soon as posible
yours representetive
Mr Yapi Aantoine
you can reply me in this my email adress
yapiantione@yahoo.com
Or
Call me 0022501307526
Apr 04, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
210 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
