Question about HP Compaq Evo n610c Notebook
Computer not booting up
When the computer is turned on 2 quick messages appear but too qiuck to read, one says something about cables. It then comes up with a black screen with white writing that says insert boot disk and push any key. No boot disc came with it. When you push any key nothing happens. Prior to this happening it was running slow. Can you please help. Norma
    Sergeant:
  • 177 Answers
Probably your HDD data cables are bad. Try to change it and then start your PC
Posted on Nov 25, 2008
  • 53 Answers
Hiiiiiiii ther
how r u ??
the boot disk is any OS bootble CD or disk start up
plz tell me more so i can hellp u
what is ur machine ?
what is teh problem ? is it running slow or u need to boot ?
and if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Why did my computer monitor stop showing an image?
Disconnect it from computer and power. wait 15 minutes and plug only the power back in, press the power on button. The monitor may display a message that there is no signal or something like that. If that happens the problem is either the cable or the computer. If you get no message then look for the menu button and press it to see if any thing appears. If not find the manual on line and read it. Many times monitors get over-driven by computers to the point that they can't display OR they self destruct.
OR
Another way is to just unplug everything computer and monitor for 15 minutes. Plug in monitor first then plug in computer and press the power button, the display should display the booting information if the cable is good and the monitor is good.
Jul 19, 2014 | ViewSonic Computers & Internet
How to boot to CDROM? unit: IBM Intel Pentium 4 1.8 ghz
At power on, you should have an option to hit F12 or another key for boot options. From there choose CD/ROM
Aug 08, 2010 | IBM Netvista Intel Pentium 4 2.4GHz /...
Reads boot disk failure 0
Boot disc 0 failure is usually indicative of the failure of the hard drive that contains the operating system. Make sure the hard drive is well seated into the cables and that the cables are seated onto the motherboard. If it all is well, then the hard drive has most likely failed and needs to be replaced.
May 19, 2010 | Dell Dimension C521 PC Desktop
Computer will not re-boot
your hard drive has been corrupted due to improper shutdown
Oct 07, 2009 | Dell Dimension 3100 PC Desktop
My acer aspire one, have en error realtek, somting about ethernet. then the windows don't go up. so start with the screen that said windows, and quickly appear a blue screen with a message unmountable...
If it be the connector cable problem then replace the 40-wire cable with an 80-wire UDMA cable.
If it's a BIOS settings problem then load the 'Fail-Safe' default settings, and then reactivate the most frequently used options such as USB Support.
If it's a damaged file system case then:-
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Aug 12, 2009 | Acer Aspire One PC Notebook
Monitor won't stay on. Error message comes up that says "no input signal", then monitor goes out.
Problem with the monitor, monitor cable, or video output. For monitor, if you have more than one input, make sure it's set to the correct one. Try a different cable. Try a different monitor. Check your video card settings--if you see the BIOS bootup screen while it's coming up then the Windows splash screen, then monitor blanks out, it's a Windows display setting. Boot into safe mode, then change settings--
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 31, 2008 | HP Computers & Internet
Computer turns on, but does not boot to XP
Generally, fans are controlled by heat readings...something to check is the operating temperature that is shown in your BIOS when you boot up...(access your BIOS by tapping on the delete key, or F2 key while booting)..if it goes over 70C real quick then there is a CPU heat dissipation problem, which would cause the fan to run like this i think that it is more of an issue that your CPU died...has your machine taken any kind of hit or fall that might have loosened things?...or perhaps the heat sink compound between the heatsink and CPU failed.....
but it also could be a dead MB
Jun 06, 2008 | Sony VAIO Digital Studio PCV-RX660 PC...
Isn't being read anymore
Please repair the master boot record(mbr) might be damage cause of viruses. If the harddrive detected in the CMOS there is no possible that can able to format the harddrive using windows utility such as XP Bootable CD or 98SE.
Hope this will be helpful to you.
Oct 25, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
HP Compaq Evo n610c Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
