Question about Toshiba 36AF61 36" TV
Loss of colour
I have a Toshiba 32" Pro logic tv model number 3357db which has lost its full colour leaving a green picture I have tried adjusting brightness/colour etc with no change, any ideas? What will it take to fix? Can we do it ourselves? How much will it cost? It is a UK product approximately 12years old Many thanks Ju
  • Anonymous Apr 08, 2008
    I HAVE A TOSHIBA MODEL 57H83, COLOUR LOSS ON TV BUT COLOUR FINE WHEN PLAYING DVES.
    Sergeant:
  • 308 Answers
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Posted on Jan 03, 2007
Colour loss
Try a reset to this set and check. If it do not help you, contact any service technician. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Apr 04, 2015 | Toshiba 32BV700B 32 in. LCD HDTV
What is the Remote Model for TOSHIBA Colour TV Model 2168TIV
In my opinion, you should not have to give them the remote number, but you can look this up by contacting the customer service website of Toshiba, giving them the model number of your tv..and explaining your situation...also check eBAY for remotes.
Sep 10, 2014 | Toshiba Televison & Video
Toshiba regza tv switches on but has no picture or sound
I can try to help but: what is the model number and how old is this set? Model and date made will be on rear of set.
Dec 19, 2012 | Toshiba Televison & Video
Tv red screen
nice to have model number.
tap on crt board with a plastic handle see if it goes away.
otherwise it sounds like the tube is bad, you could also try to adjust the red brightness screen
Feb 01, 2008 | Televison & Video
Owner Manuals
please open it & give model no &download the manual
http://tv.manualsonline.com/
hope this will help.
Oct 18, 2007 | Toshiba 32AF43 32" TV
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
RCA F31317 lost blue in picture.
this symptom is characterised by the loss of one or two primary colours. this symptom can be classified into three cases: 1) loss of red colour, 2) loss of colour blue,3) loss of green color. this symptom may be caused by a trouble in the colour demodulator, in the color amplifier or in the colour subtraction amplifier circuit. in your case loss of blue colour. this is a very complicated problem that you need some special test equipment like oscilloscope and color pattern generator in order to trace the signal. tune the receiver to a color broadcast station(a colour bar generator can be used to transmit a colour signal to the set). check the Z-axis demodulator, z-axis amplifier and the B-Y output circuit for the chroma signal. observe the signal process with an oscilloscope. if the color signal is not present use a VOM to locate the defective component in any of the above circuits. check the transistors and the resistors in the collector circuit. good luck!
Feb 14, 2007 | RCA F31317 31" TV
32" Toshiba television Mod. 3357DB
If im not mistaking I remember the toshiba 32" to have an on screen alighnment in the sevice menu.. and I would not recomend that anyone without the proper manual and tools to fool with these adj as I've seen in the past that a set had to be completely redone even the tuner alighnments after someone went in and tryed to adj the set., Now the green tinge you speak of is the CRT getting weak The best way to ajust this would be to see if on the picture tube pc board on the end of the Picture tube if it has any little control on it ? if it does look for the green drive and put on a b&w Picture. slowlty turn down the green drive control untill the pic look almost B&W and you probably wont be able to get perfact grey scale as the crt is weak . If theres no controls on the crt pcb then your gonna need a service alighnment manual and adj the green drive that way. Good Luck
Apr 24, 2006 | Toshiba 32A60 32" TV
Toshiba 36AF61 36" TV Logo
354 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
