Question about Acer Aspire 3100-1405 Notebook
Window error recovery
I turn on the computer and immediately receive a window error recovery message. It then starts to load normal startup and the screen goes dark with no completion of loading
  • 53 Answers
Hiiiiiiiii ther
how r u ??
u have OS problem u need to reinstal teh OS
and if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Posted on Nov 25, 2008
Computer won't boot stuck in Error RecoveryScreen won't go any further
You should be able to do a clean install of Windows. Just insert the installation disc and press any key when indicated. Optical drive needs to be the first boot option. Go into BIOS and change it is not.
As for disc, you have to use the same Windows version as indicated on the MS Product Key sticker, because of the serial number.
May 24, 2013 | Toshiba NB205-N210 Netbook
Aspire 5475 freezes on startup
It is most certainly a driver, but if you cant access the safe mode also that could be a hardware issue.. Try to troubleshoot with a windows installation cd. Put it in and boot the pc. It will start the windows instalation, you choose repair computer and not install windows. The command prompt will open, try to troubleshoot from there.. Thanks!
Mar 19, 2013 | Computers & Internet
I have a Toshiba Satellite A135-S2276 laptop running Windows Vista. The laptop was dropped from about 12 inches by my child. When I opened Explorer, it was acting funny, so I rebooted. The main Toshiba...
Windows is corrupted beyond repair, you need to reinstall it. For the recovery discs, call Toshiba at 800-457-7777. They will want to know the computer's serial number and a credit card number.
Sep 09, 2010 | Computers & Internet
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
1. Click Start, click Run, type msconfig, and then click OK.
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Sep 04, 2010 | HP Pavilion dv7-1130us laptop
Ok so I'm fixing this Gateway M-6843 for a friend... When I turn it on it will try to boot but then it goes to a bios looking screen and says Windows Error Recovery at the top and it gives the options of...
It smees your windows having some problem. It might crash.
try to boot the PC from CD, repair the windows. if it cannot repair, then better do fresh loading.
Aug 21, 2010 | Gateway M-6843 Notebook
Computer wont go past a blue error screen
Your hard drive may have quit(died). No good solution other than replace the hard drive. Do you have a restore disk for you computer, to use after replacign the HD?
Here is the website for Acer PC
Dec 19, 2008 | Acer Computers & Internet
My laptop turns on but brings up a blue screen
windows is corrupted reinstall by using windows xp cd
Jul 10, 2008 | Compaq Presario 700 470024-192 Notebook
Acer Aspire 3100-1405 Notebook Logo
69 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
