Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
No picture, no sound
I have a Mitsubishi DLP - WD62725. TV comes on but there is no picture or sound. No flashing lights on the front, only the 'green' power light and that is steady. We are able to control the volume on our audio tuner, which runs through the TV (can see the dial turning the volume up or down). But no picture or sound? Is this the bulb? Or something worse?
  • 22 Answers
The green steady power light is a good thing, how old is the TV?
If you are routing your audio and video through the audio receiver, make sure that the inputs are correct on the display of the receiver, ie. IF you are planning to watch your DVR and it is hooked up on Component 1 for video and Coaxial 1 for audio, make sure that the receiver is still programmed for this in the input of TV/Video 1 or whatever the input. I have ran into this on countless occasions, simple fix, but a headache until it is tracked down. Double check the connection to the TV as well.
Posted on Nov 25, 2008
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
No picture or sound on TV
Have you activated the self check this set has that will indicate what error was picked up?
Dec 20, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
Jul 17, 2012 | Mitsubishi WD-60735 Projection Television
Problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture...
Lets try an error code operational checl. Unplug the tv and plug it back in. With the standby LED on press and hold the MENU and DEVICE/INPUT buttons for 5 seconds. The LED will flash a certain number of times pause for a while and blink again. Count the blinks before and after the pass, then post it here so that I can tell you what the problem is
Mar 27, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
The picture on my Mitsubishi WD62725 is starting to show some wavy lines and snow. We had a repairman come and he said that it needs a new chassis which would run around $550 and he said that it was not...
If the set is 6 years old I would not put $550 into it, but a new 60-65 DLP should only run you from 1200-1800. If you check around you will find alot of Mits DLPs on the internet for even less.
Jan 08, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Problems with mitsubishi WD 65737 tv is locked. what do we do?
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
Oct 20, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Tv problem mitsubishi wd62725 ir location
This remote device works on pulsed IR beams to work, and the fact that the screen refreshes very close to the speed of the controller could be causing the reliability problem..Sorry I don't have a better solution for you....accordianman
Nov 11, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
148 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
