Dell laptop inspiron 5150 wont come on
Xp the power comes on with the lights it seems like it starts to boot up but the display wont come on and just the cpu fan runs i tried a new hard drive but didnt help
  • mark_jordan9 Nov 25, 2008
    i did try to reset the memory card
Did you try re-seating the ram? I repair and resell computers. The most common problem with laptops is the memory modules become unseated from moving them around. The screen won't light on most of them if the ram becomes unseated. Just remove the ram cover on the bottom, remove the modules and reinstall them. A bad module will do the same thing. If reseating them doesn't work, try removing one and then the other to see if you have a bad module.
Posted on Nov 25, 2008
My dell inspiron 5150 couldn't boot on or show power light.the board cant start.
The issue can be due to corrupted display drivers or graphic adapter malfunctioning.
Visit the below link for more information
http://notebook-solutions.blogspot.com/2009/07/my-laptop-computer-will-not-boot.html
Aug 14, 2010 | Dell Inspiron 5150 System Board (...
Blank screen on start up. No dell logo. Only
have u tried resetting it (u may loose it all)
Apr 14, 2010 | Dell Inspiron 5150 Notebook
Flashing cursor on inspiron 5150
I assume the power LED is on when you boot up the laptop and the power adapter is OK.
If I understand you, the RAM module is in memory slot A and not in slot B. If not the RAM module needs to be in slot A.
When a laptop doesn't the RAM module may only needs re-seating or the RAM module is faulty.
Re-seat the RAM module, and if this then take the RAM module and get it tested at your friendly computer shop.
Dec 11, 2009 | Dell Inspiron 5150 Notebook
3 Lights on display panel Dell D505
YOU HAVE A FAULTY BIOS.I HAD THE SAME PROBLEM WITH MY DELL INSPIRON 5150.REFLASHING THE BIOS SOLVED THE PROBLEM.GOOD LUCK.
Sep 11, 2009 | Dell Latitude D600 Notebook
DELL Inspiron 5150 isnt booting
If it doesn't respond at all with no ram or hdd, it is likely that the board is in fact dead.....sorry. When you say you found a broken pin, I assume you mean one of the contacts from the power jack to the main board had a cracked solder joint and you resoldered it. If this is the case, try disconnecting and reconnecting the connector from the lcd panel to the mainboard. It may just not be making contact. Also, if you boot up with the hd installed, do you see the hd activity led flashing like at a normal boot? If not, sounds like a dead board. Try pulling the optical drive too if you haven't already. Try connecting to an external monitor too.
Hope this helps!
Aug 17, 2009 | Dell Inspiron 5150 Notebook
Dell inspiron 5150 green light flashing on front won't boot up
I had the same problem, replaced the hard drive and problem went away. The hard drive developed bad boot sectors after downloading XP service pack 3. I found out later it isn't compatable with the dell I have. Hope this helps. Good luck!!
Apr 29, 2009 | Dell Inspiron 5150 Notebook
I have a dell inspiron 5150 and it won't start up it started with NTLDR is missing I tried to replace these files with new ones didn't work. I have 2 laptop another one is a compaq armada 1750 now the 2...
inset the extrnal dvd drive attch with usb cable and insert the orignal windows cd dell recover cd and boot timepress F12 and select the extrnal drive and start your system setup.............ok
Apr 02, 2009 | Dell Inspiron 5150 Notebook
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell Inspiron 5150 won't boot
Take out the battery. that hapened on my inspiron 3800
Nov 11, 2008 | Computers & Internet
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
