Question about Zenith XBS245 System
XBS245 Stoped working
6 months after I got the surround system it stoped working the red light stays on in the front when i plug it in and nothign happens...Is there anything i can do if there is can you help?
SOURCE: zenith xbs245 surround sound system
xbs344 stuck on prgrogriv scan have sound but no picture
Posted on Dec 21, 2007
0 characters
1 Points
Philips home theatre system hts35650 stoped working After switched off the power. How to fix it
Perhaps the surge strip has blown a fuse. Try plugging directly into a wall socket, bypassing the surge strip. If it lights up, then you know you have to get a new surge strip. In any event, it is most likely a fuse that's either in the surge strip itself or in the rear of your Philips receiver, near where the AC plugs into the chassis. All electrical appliances and devices have a fuse. Find it and take a look and see if you can ascertain if the nicad wire is broken inside.
Jan 08, 2015 | Philips Home Theater Systems
Subwoofer stoped working
Depending on usage, may have blown out.
Apr 02, 2014 | Harman Kardon BDS 370 Home Theater System...
EZW-RT10 (S-Air) surround speakers not working (power/on-line button) flashing. Was working fine for a year, then stopped working.
Do you need a new pairing of surround. select the pairing menu at the home, turn on the surround and press the button that is below the s-air cartridge. A red light will light the rear surround and make a new pairing.
Jun 05, 2010 | Sony DAV-HDX678WF Theater System
I a have the xv-dv77 and the buttons on the sytem
Hi, I have the same system and had the same problem with the drive door refusing to open when you press the open button. I fixed it quite easily, unplug every thing, on the rear of the unit, remove the two screws holding the top rear cover on. This will reveal two plastic securing clips for the front top cover, release these and the top cover will slide off easily. You will find that there are two bent over hook wires, where the button is and if you look at the under side of the top cover, you will see two metal contact strips that are suppose to touch these wires. All i did was bend the wires out a little so that they made better contact with the sensor strips. Put it all back together again and hey, it worked right away. Good luck, Richard
Oct 28, 2009 | Pioneer XVDV830/SDV830 DVD AUDIO HTP...
Rear surround sound speakers not working during movie.
Look on your manual, page E16. Go into your speaker setup. Select your speakers (Front,C,Surround, Sub) and make sure each are selected as "small" (make sure you go through each one). If the surrounds are selected as "none" the rear will not activate and will light up as red on the display. Let me know if this helps.
May 02, 2009 | Koss KS3102 System
No sound from back surround speakers
We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
Jan 11, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Unit stays in standby, no disc movement, I think it needs a reset?
If you want to sell your broken receiver, please let me know, I am willing to buy it off you.
May 12, 2008 | Sony DAV-FC8 System
Zenith xbs245 surround sound system
Dec 20, 2007 | Zenith XBS245 System
Surround Not Working on TV
well for one thing .. on cable it has to be in surround sound.5.1 or 6.1 for it to true surround.your dvd and cd will be fine .. if you just want to have sound coming out of all speakers you have to adjust your sound settings but it will not be surround sound though
Nov 24, 2006 | Sony DAV-DX250 System
Zenith XBS245 System Logo
Top Zenith Home Theater Systems Experts
Electro Med Services...
Are you a Zenith Home Theater System Expert? Answer questions, earn points and help others
