Question about Samsung RS2578BB Side by Side Refrigerator
Ice cube dispenser not working
Getting water into the ice cube dispenser, it is freezing into ice cubes, but when dispenser turns to dump the ice cubes, they won't come out. It then adds water to start over and overflows. Help! Not sure what gets the ice cubes dumped out of the tray.
I had this problem. The root cause was that mineral deposits had built up in the ice cube tray. The ice would not "dump"... but stayed in the tray after the dump cycle. I did not catch it quickly and eventually the plastic frame broke. That was easily replaced. Inspect the ice tray to see that all cube surfaces are smooth. If there are mineral deposits, they need to be removed. Do NOT scrub with anything abraisive or you will ruin the tray. As you are looking straight on at the Ice maker, with the bin out, depress the small black retangular tab. The tray assembly will come apart to remove the tray. Rinse the tray, then fill with warm vinegar. Let it soak. You may scrub with soft cloth, finger or fingernail to remove deposits. Replace the tray and you should be in business.
Posted on Oct 14, 2009
I have a Samsung RS2555SL and experienced the exact same problem. Water filling the tray, forming ice, dumping into bucket, depress flap at door, flap inside door opens, motor for corkscrew in bucket turns just fine - but no ice dipensed thru door. Samsung phone tech said cubes too big, must decrease amount of water filling tray to create smaller cubes. I went thru every setting, dumping buckets of ice between settings - still no ice thru door.
My problem was that ice could not get from bucket to door. I looked real close and noticed the the metal "corkscrew" attaches to a metal "blade" which is in front of the grey cylidrical swirly thingy that shoots the ice down thru the door. I noticed that the metal "blade" attached to the corkscrew has notches in the edge which seem to fit into grooves on the front of the grey swirly thingy, but mine was not fitted into the notches correctly.
I held the grey swirly thingy with one hand, and gently pried the metal blade around to what looks like the proper notches, and voila - this opens up the "gap" between the metal blade and the grey swirly thingy. I dumped all sizes of cubes back into the bucket and danced joyously around the kitchen while the entire family successfully dispensed ice.
I apogize for the aformentioned technical speak, "grey swirly thingy" is industry jargon. :-)
Posted on Apr 25, 2008
    Problem Solver:
  • 17 Answers
Answer for brett30
the problem your having is easy as a fridge engineer i see this one a lot
on the ice door is a motorised flap which openes to let icecubes through,it has frozen open so letting fresh air into the ice dispenser door this melts the ice in the bucket sticking it together so the crusher cannot dispense
op3en the door look into the disp tube and see if the flap is open if so use a air dryer to defrost then dry with paper towel problem solved
Posted on Mar 10, 2013
  • 237 Answers
Not real familiar with that specific model but it sounds like the heating element isn't working to loosen the ice from the tray as it's dumped. A typical ice maker has a small heat element under it to melt the surface of the ice just slightly while it dumps.
Posted on Jan 04, 2007
My ice maker inst working Whirlpoo; model gz25fsrxyy2
By "ice maker isn't working" do you mean it isn't filling with water, it isn't freezing the water in the ice maker, it isn't dumping the ice cubes into the bin, or it isn't dispensing ice cubes?
Was it previously working and it is not working now?
Typically one can hear the valve when it opens to fill the ice maker with water. Can you hear it attempting to do so? If so, and there isn't any water in the ice tray, check that there is water supplied to the valve at the wall and the valve is open. Is there a water filter? Has it been replaced per the manufacturer's recommendation? (Typically, the water filter should be replaced every six months.)
Is the "full" bar pushed up? It shouldn't be. The bar above the ice cubes should not be in the horizontal position. That position tells the ice maker the bin is full so it should wait until the bar goes down, indicating some ice has been used.
Can you hear the bayonet turning? Is the ice maker attempting to dump out cubes whether or not they exist? The next issue after you confirm there is water going into the ice maker that is being frozen and the ice maker knows to dump the ice, is the bayonet. There is a motor that turns the bayonet and a mechanical connection. Either could be at fault.
Jan 22, 2018 | Refrigerators
My icemaker stop working but the water dispenser still working I check both water lines from the filter its ok but can't check the freezer line by icemaker. turly don't know why the water will not flow...
If there is no ice in the ice mold of the ice maker, you can pour enough water in to make cubes, wait an hour or so for the icemaker to cycle.( freeze and dump the ice). If it does, then your water valve on the back of the refrigerator that the main water line hooks up to is bad. Replace it. The valve has two sides to it. An ice maker side and a water resevoir side. One side can be bad allowing the other to work.
If the ice maker does not cycle and dump the cubes then you probably have an ice maker problem.
Jun 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Ice maker doesn't work
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps the cubes , but doesn't fill with water , replace the water inlet valve ( the piece that the wall water line connects to on the fridge ) . Also check to be sure that the fill tube from the back of the freezer to the ice maker , isn't blocked with ice , as this is caused by a seeping bad water valve . If the ice maker doesn't dump the cubes , after freezing , then replace the ice maker . Also check to make sure the coils under the front of the refrig , are clean of dust , lint , pet hair , etc.
Sep 16, 2009 | Refrigerators
Cubes won't dump into the storage bin
In photo below you can see the heating element that comes on moments before the ice maker drops the ice. If not working then the icemaker will struggle to unload. You need to unplug the refrigerator and then unpluge the ice maker and remove it to test these parts. Test with a multi meter or ohm meter. Test the 2 connections next to the number #26. Hope this helps, Sea Breeze
May 21, 2009 | Whirlpool GS5SHAXN Side by Side...
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Nov 21, 2008 | GE GSS25LGM Side by Side Refrigerator
Samsung RS2578BB Side by Side Refrigerator Logo
1,638 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
