Diagram indicating soldering of wires to the DIN plug (Logitech X220 speakers). My three of the wires broke just before the DIN plug.
  • 165 Answers
Hello oh well you need to open the device to know how they are connected ...you need a voltmeter to check which one of them go signal,volts,ground etc.......saludos
Posted on Nov 25, 2008
Wiring diagram for the radio on 2004 range rover HSE with harmon garden sound
I believe the radio in the Range Rover is wired DIN standard which is used with some minor variations on the majority of European cars across Europe.
I think there are three multiway plugs plus antenna. One plug provides four pairs of speaker wires, one plug carries all the power requirements and the third plug provides a bunch of wires for the steering mounted remote control.
Sorry but I don't have a diagram to hand but you shouldn't have much bother finding one.
Feb 04, 2015 | 2004 Land Rover Range Rover
Radio pro 4 wiring
You should purchase a radio harness for your car, and it's wires will connect to wires of the same color from your JVC radio harness. Join the two harnesses together (solder, crimp caps, barrel connectors, etc.) and then one end plugs into your JVC, the other end plugs into the factory harness that the original radio was connected to. If for some reason, your factory harness plug has been cut, you'll have to hardwire the JVC harness. I've included a link to the wiring diagram for your car. The steering wheel controls are moot; they will not work unless you've got some aftermarket adapter that allows them to interface with the JVC radio.
2004 pontiac grand prix speaker wiring diagram Google Search
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Nov 13, 2017 | Car Audio & Video
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
Logitech headset usb wiring diagram?
Is this what you are looking for?
Jul 10, 2012 | Logitech USB HEADSET H390
My speakers aren't getting any power. I feel confident I have traced power all the way to the switch. Would anyone have a schematic diagram for Logitech x-240 speakers?
Hello little richi,
I would suggest plugging your speakers into another outlet first to be sure that your speakers are the problem. I would then suggest to check and see if you can remove the power cord, which I would assume is universal and can bought at many retailers, and install a new one.
If the switch was the problem, this situation becomes more technical. You most likely would have to buy a new plug. There are electronics retailers such as Jameco and Newark. We're not talking about places like Best Buy and Walmart here. Jameco and Newark sell plugs that you would have to solder on to the wire. The plugs should be real cheap. If you know how to solder, all you would need to do is solder the wires on to the plug.
Jul 20, 2011 | Logitech X-240 Computer Speakers
Need wire diagram 4 altec lansing acs295 4 red connctor
I have the same speaker set. maybe we can help each other. My plugs are all fine but my sub is not connected to anything at all and I need to know were they must go on the pc board. Maybe we can trade some photos on the wiring diagram?
Mar 14, 2009 | Altec Lansing ACS 295 Computer Speakers
Broken D-sub cable
I would advise against a direct solder inside the unit. I would go and purchase a replacement connector from a Radio Shack or other electronics parts store. Solder wires to this, then plug in, should fix problem.
Apr 03, 2008 | Logitech Z-2300 Computer Speakers
Wiring for Altec Lansing avs500
Hi, from a very old Altec ACS48 : Green - right speaker Red - left speaker Black - common, ground White, Yellow & another Black - power switch Orange - Led indicator Below is the pin layout
Jun 24, 2007 | Altec Lansing AVS 500 Computer Speakers
138 people viewed this question
 Grubhead
Grubhead
