Question about Bosch Kitchen Ranges
In the middle of cleaning it started beeping and error 154 came up on the screen
  • sidney1019 Nov 25, 2008
    the range number is one of these three...does this help HDS252U, HDS255U, or HDs256U. The door is still locked from the cleaning so I can't get the exact one, but this is what is on the manual
    The error was gone this morning but when I opened the over the inside glass on the door was shattered!!!! UGH. What should I do? Who should I call?
  • 4,806 Answers
Whats the model number of the range please
Posted on Nov 25, 2008
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Nov 25, 2008
    Resetting the factory settings.
    1. Access SELECT FUNCTIONS Menu.
    2. Turn knob clockwise until RESET DEFAULTS is
    3. Touch START. Display reads SELECT
    try and see if this works
  • Lee Hodgson
    look here for all the manuals select "instrution manuals" enter HDS252U in the box :
    good luck
  • Lee Hodgson
    WOW!!! i have never heard of this before, you must get this looked at by a professional whether its still under warranty or not! This probably should not have happened and was the initial cause of the problem in the firs place.
    here is the web address for, choose your country and it will no doubt provide you with a telephone number and assistance:
    kind regards
Error code 154 on a bosch oven
The 154 error indicates that the electronic control board that acts as the master control for the oven got too hot. This sometimes happens when the oven vents get blocked. Make sure that there is space between the oven and the wall. Check that the oven is raised a bit above the floor. (The exact clearances may depend on the model.) Next unplug the oven (or turn it off at the circuit breaker). Pull the oven out from the wall and clean the louvers if they are dirty. Check the wiring in the oven for any shorted wires. If the wiring has damage, replace it.
Unfortunately, since this happened in the self-cleaning mode, the electronic control board may need to be replaced. Please add a comment with the model number of your oven, if you would like me to give you the part number you need. The model number is often inside the oven on the door frame. For some models, it's on the inside of the drawer front of the drawer below the oven.
I hope this helps.
Jun 25, 2016 | Bosch Kitchen Ranges
Printer not printing
Under the troubleshooting section(pg.154) it lists this error as having one of two possible causes:
just do CTRL plus f to find
Unable to Clean XX
in the pdf document
As you failed to mention the model number it may not be your model number but the basic principal will be the same on the cause.
Jun 10, 2016 | Brother DCP Office Equipment & Supplies
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
We have had our Cabrio for several years (gas dryer). Suddenly, in the middle of a cycle, it starts beeping? Why? The Lint Screen is clean etc...
Try to vac out where the lint screen is. Might try to vac out the exit, does the outside vent cover open when its running?
Oct 31, 2014 | Dryers
It says dr and beeps on my frigidaire front load washer
Hello shadow183 - Typically DR is a generic door error code. Possibly the door is not shutting properly, either it is sagging and not latching properly or the door sensor and the main control board are not communicating correctly. You would need this to be diagnosed by a professional technician in order to properly repair the machine.
Sep 27, 2012 | Frigidaire ATF6000ES Front Load Washer
Approximately 2 hours into the self-cleaning cycle the range starts to beep, displays error 154, and stops. Does anyone have any suggestions of what is wrong and how to go about fixing it.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
May 04, 2010 | Bosch HGS5052U Gas Kitchen Range
Erro sound/pip when ibm 8310 netvista starts, no error message are show on the screen, the screen are black.
how many times it beeps is an indication of the problem
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard cardhope this helps.
Sep 14, 2009 | IBM (09N5424) Motherboard
I get a "beep" in the middle of gameplay on my HP D330
Hi, it,s possible that the game your running is crashing up, due to lack of system memory. this usually happens if for instance:- the graphics card or Ram can,t cope with the amount of charactors or pixels, needed to be displayed on the screen. check the games minimum system requirements are met for that specific game. also check that Direct X drivers are correctly installed. Mike @ compurepair.
Jun 11, 2009 | HP D330 Microtower (DS619A#ABA) PC Desktop
Computer beeps when I try to start up
No Beeps
No Power, Loose Card, or Short.
1 Short Beep
Normal POST, computer is ok.
2 Short Beep
POST error, review screen for error code.
Continuous Beep
Repeating Short Beep
One Long and one Short Beep
Motherboard issue.
One Long and Two Short Beeps
Video (Mono/CGA Display Circuitry) issue.
One Long and Three Short Beeps.
Video (EGA) Display Circuitry.
Three Long Beeps
Keyboard / Keyboard card error.
One Beep, Blank or Incorrect Display
Video Display Circuitry.
Jan 05, 2009 | HP Computers & Internet
Kitchen Ranges Logo
35 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Joseph Hoffmann
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
