Question about Desa International ReddyHeater® R115DT Utility
My reddy heater works but its kickin out to many fumes
It burns my eyes
  • Anonymous Dec 25, 2008
    Mine is doing the same thing. This is my second heater like this, because the fan motor burned up in the first one. The first one worked great. It could run indoors all day without fuming up, but the new one will gas you out in just a few minutes
  • 61 Answers
It needs to be tuned up and nozzle changed. also electrodes will need to be cleaned and set.
Posted on Nov 30, 2008
Reddy heater 170T- terrible fumes-fuel pressure problem
Are you sure there is not water in the tank? Fuel pressure should almost never need adjusted.
Jan 08, 2014 | Reddy Heating & Cooling
I have a reddy heater 100 pro it stinks when it is going and burns my eyes
If you are using it inside, in an area that is not well ventilated, that is the problem. In addition, if this heater is in a work area and there are paint or stain fumes or anything similar, the heater is picking up those fumes and making them 100 times worse.
Also, is the heater has not been cleaned and service regularly, this also could cause the odor, due to incomplete combustion. Also, how old is the gas in the tank you're using. Old LP Gas can also cause the odors.
Those things listed above, are all things that can cause the problem you described. Resolving those should take care of the odor problem.
Feb 12, 2011 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Reddy heater R100B gives of fumes when i use it
Not familiar with the R100B unit. Is it kerosene, propane or something else. Anytime a combustible heater gives off fumes it is not burning the fuel completely. This could be clogged filters, wrong fuel ratio or something else. Send me more info and I will try to solve your problem.
hardrocko
Jan 31, 2010 | Reddy Heating & Cooling
Raw propane fumes and burning eyes
Ours didn,t burn liquid propane too well, so ccheck your connections on your tank for vapor or liquid.
Dec 17, 2009 | All-Pro Propane Garage Shop Heaters - All...
Ive got a reddy heater pro 155 when you turn it on it runs rich burns youre eyes fumes i took it to a man that works on them here local and he said the board that controls fuel mixture was bad what do you...
Are you sure it is running too rich? Your eyes will also burn if it runs too lean because the hyrocarbon and nitrous oxide balance is off. If too rich, there usually is a smokey vapor that is emited, whereas too lean does not create any seeable vapor.
If youhave a little tech to you, you can over-ride the control board and have the power go directly to the burner (as is in the older burner models). If you get the same results, then you'll know itis not the control board. Goodluck,Macgivor
Oct 25, 2009 | Reddy Heater-30-55,000 BTU Variable
Burning eyes and sore throat when heater is on
This heater should only be used in a very well ventilated area, the sore throat and burning eyes are from carbon monoxide.
Carbon monoxide is potentially fatal.  I cannot express how dangerous this is if used in a house or garage without the doors open
Please be careful and let me know if I can provide furthur assistance.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Mar 02, 2009 | Reddy Portable Forced Air Propane Heater...
Fumes
One of two things, a high heat limit control or the flame sensor, also check your air line that runs to the heater nozzle could be cracked, not enoughair to fuel mix will make it burn dirty.
Dec 14, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Desa International ReddyHeater® R115DT Utility Logo
96 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
vance jones
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
