SOURCE: i cant find the vin number on my 1997 yamaha gp760 pwc
looking in the manual page 1.1 if removed its been stolen
should be stamped #'s an text on a sticker or can call in the engine serial #
yamaha engine serial
yamaha GP760 manual
SOURCE: Overheating YAMAHA XLT 1200 jet ski
you may have something clogged in a water passage but more than likley u have a bad sensor the sensor is located on the main exhuast if you go on the right side of the ski and look in the engine compartment it will be located at 9 oclock u will see it sticking out of the exhuast with one wire comming out after u run the ski and the buzzer goes off pull the seat and see if the engine is really hot if u can not touch it will be hot but it has to be very hot for the sensor to pick it up if u can touch the motor and exhuast it is a bad sensor
SOURCE: 2000 Yamaha jet ski runs great for the 1st 5
Water inlet screen or hose is plugged.Water travels from the jet pump,closest hose to the impeller,up to the cylinder,head and then through the exhaust.When you restrict cooling the exhaust sensor tells computer to go into limp mode.{Bogs down}Had a couple of other ones that had **** stuck in fuel line pickup tube,remove fuel filter and see if you can blow back into tank.
SOURCE: ''how to replace starter in 1993 jet ski''
Unbolt the electronics box (swing out of the way), take off the box mount plate, and remove the exhaust upper manifold and expansion chamber. This should give you good access to the starter.
SOURCE: have 1200 xlt yamaha jet
This motor has 2 accelerator pumps on the carbs, pull the choke, turn it over for about 5 seconds then pull the throttle trigger 2-3 times and it should start right up, then push in the choke.
