Question about Sony Xplod CD Player w/MP3 Playback CDX-GT50W
Cd player and amp suddenly stopped workin
I unplunged my cdplayer from the harness and now after i plugged it back up its not showing power or anything
  • 199 Answers
Try resetting the unit, and double checking the fuses, also make sure none of the panel buttons are stiff or jammed.
Mark
www.blueice-electronics.co.uk
Posted on Nov 25, 2008
How do i wire me cdplayer in to my s10
You can get an adapter for $6 so you don't have to cut the original wiring. It connects to cd player wiring then just clips in to your stereo harness that is already there. Otherwise if you are going to cut your wiring, you will have to go to installer . com or the12volt . com to find out which factory wires are which.
If you get a wire harness, then just match up the colors that are on the cd player.
Red wire is from ignition
Yellow wire is directly connected to the battery power
Black is negative ground wire that should be grounded out.
Blue wire is an acc wire that connects to the REM on an amplifier.
Orange dimmer isn't needed and blue/white power antennae wire isn't needed.
Green and purple wires are speaker wires for the back and white and grey wires are speaker wires for the front.
Sep 29, 2010 | Car Audio & Video
I want to change my original cd player for a pioneer
This is because you need to purchase the aftermarket-oem harness plug.This harness plugs into your original equipment radio harness and allows you to plug any aftermarket radio into the stock deck wires.After you plug the harness in you can then connect the radio wires together.Your local autoparts store or circuit city or best buy or audio express will have these radio conversion plugs.I hope I could help
Dec 24, 2009 | 2003 Ford Explorer
Hi my yellow battery lead with the fuse
Are you using AMPs? You may have everything connected right but, when you turn it on the battery doesn't have enough supply to operate the system. This happen to me and I had to change my alternator, and battery.
Oct 24, 2009 | Alpine CDA-9887 CD Player
Car radio/cd player cuts off radio will not play cd will not play ,hit the power button and will come back on some times it wil not. its seems like there is static sound when the music does not play on the...
Hello pinkperry,
It sounds like the wiring between the cdplayer and the dash has come loose. When the wires are not making proper connections some of the speakers or functions of the radio cut on and off.
This is just my first thought and the easiest thing to fix. You will have to remove the cd player from the dash. After which you will want to check the wiring. Chances are your cd player has a harness if it's an aftermarket cd player installed in your car. If it does there will be two sets of wires to double check.
Just make sure all the wires are securely twisted together (the sets of wires) and taped up with electrical tape.
Try that and post back if you have any further questions. Thank you for choosing Fixya!
Aug 25, 2009 | Car Audio & Video
VR3 cd 400 where to get wiring plug to go in back of player
Do you need a wiring harness for the back of the unit? All you have to do is google "wiring harness for vr3 cd400 and you will have allot of options to choose from. If you connected the red which is 12v +, yellow connects to 12v for radio memory, and black goes to ground. Brown is for external amp turn on. Check to make sure your connections are correct. Do you have an adapter harness that plugs into the factory radio harness? You can get one from Wal-Mart or best buy or online. So you don't have to cut/splice into the wiring harness coming from the stock radio.
Aug 25, 2017 | Virtual Reality Sound VR3 CD Player w/ USB...
Putin in a cdplayer
go to a local walmart or advance auto store you can get the dash kit along with the harness to plug into you factory plug the wires from that should color code match any aftermarket radio
Oct 25, 2008 | 1993 Chevrolet C1500
I have problem vith my cd player in my car.It show me error11,my cd plauer is pioneer deh2600r.What shoud i do,help me.
If a car CD Player stops reading CD's, the LAST thing that will get dirt is the laser lens.
For cleaning the Optical Pick-up of the CDPLAYER You'll have to disassemble it completely and clean the internal mirrors.
If you don't know how to do this, or you don't have the tools, take it to a service center or you can run the risk of breaking the entire laser mechanism (it cost a lot of $$$ to replace, specially in a car CDplayer).
Nov 09, 2007 | Pioneer DEH-P6600 CD Player
Splg580a
Im pretty sure this is to do withthe laser, try using a cleaning cd, put your head next to the player and listen to if the actual disc is moving inside.
this might evan be a problem with the cd motor.
Regards
Nov 01, 2007 | Technics SL-PG480A CD Player
Ate my CD
looks like the tray is offline so basiclly its not reading the first disc because its far away from the eye so by putting another disc in and it reads it because the eye is close enough to read it .  u may have to open the player up to get the first disc out.  good luck.
Oct 24, 2007 | Pioneer DEH-P690UB CD Player
IC POWER DAMAGE
take the unit off the wiring harness and hold unit in your hand , find the reset and push the reset button for 7-10 seconds....afterwards plug in the harness and turn on the unit...and it should work as new...i hope this helps...i have the same unit
Jul 28, 2007 | Pioneer DEH-P80MP CD Player
Sony Xplod CD Player w/MP3 Playback CDX-GT50W Logo
56 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
