Question about Nikon Coolpix 5700 Digital Camera
Nikon 5700+remote cable release
I brought a generic remote cable release for my 5700 from china. It is called an srt1. The first time I used it my monitor and veiw finder went black. Just the same as some of the other 5700 mentioned here. Was it the inherant problem that nixon have or was it the srt1?. Shall I try it again.
I am using the same remote on both a Nikon 990 and 995 coolpix cameras. I had trouble with the 990 but reset the unit to factory default and it appears to work in manual mode. The nikon site says that it may take 10 seconds or so for the camera to relize that it is not connected to a computer via the usb cord.
Posted on Jan 09, 2007
Cable release problem
The D3100 works with the MC-DC2 or compatible remote. See page 177 of the manual: http://www.nikonusa.com/pdf/manuals/kie88335f7869dfuejdl=-cww2/D3100_EN.pdf
Basically, you plug the remote in, then use the button on the remote just as you'd use the shutter release button.
Feb 27, 2014 | Satechi Cameras
How to lock the pop-up flash back down after using on Nikon 5700
In Auto mode it keeps come automatically when the power is on. .If you select other modes (i.e; P,A,M ) it does not but you need to pop it up manually. it stays as locked unless you do it manually.
If this does not help and If you need more info pls provide more details for additional solution..
May 04, 2010 | Nikon Coolpix 5700 Digital Camera
No instructions need to know how to operate
The Nikon MC-EU1 Remote Cord is an accessory available for the Nikon COOLPIX 880/885/990/995 4300/4500/5000/5400/5700/8700 cameras. The MC-EU1 Remote Cord is 80 cm long and allows the camera to be fired remotely like a cable release for a film-based camera.
The MC-EU1 Remote Cord's main function is to prevent camera shake. As well as the shutter release function, the MC-EU1 has the following functions.
1. operate the camera's zoom remotely,
2. advance or return images in the playback mode,
3. Controlling interval photography, automatically fire the cameras over a given interval.
Note this is the only Nikon remote cord available NIKON COOLPIX cameras and is only compatible with the cameras listed.
The Nikon MC-EU1 remote cord has two Interval modes, A and B
In Interval Mode A: the first photograph is taken at the start; and subsequent photographs taken at the specified time intervals, thereafter.
In Interval Mode B: the first photograph is not taken until the specified time interval has passed and subsequent photographs taken at the specified time intervals.
These modes can be selected by pressing the MODE button. The device cycles through settings in the order, Remote Mode, Interval Mode A, and Interval Mode B. When the Remote Mode is selected, the LCD panel displays Remote; when Interval Mode A is selected, Interval appears together with the letter A and Interval Mode B is indicated by Interval and the letter B.
The interval Modes, allow you to take photographs one after the other at a selected interval, which can be set in increments of one second to any value from two minutes to twenty-four hours. Interval modes are only available when the camera is in recording mode and cannot be used when the camera is in playback mode.
Setting the Interval
1. Setting the camera to recording mode and the remote cord to Interval Mode A or B, the interval setting will be shown in the remote cord LCD display. Items currently selected for editing will flash. Each time the selection (SEL.) button is pressed, the item selected will change as shown below.
Select the desired time by altering the settings (second [S], minute [M], or hour [H]) one at a time. While the item is flashing, press the down button to decrease the time set, or the up button to increase the time set. The value displayed will change by one each time either button is pressed.
2. After adjusting settings, press the selection button until the display is no longer flashing.
Starting Interval Mode Photography
• Half-pressing the remote shutter-release button has the same effect as half-pressing the shutter-release button on the camera, readying the camera to take a photograph. If the interval is set to less than two minutes when the shutter-release button is half-pressed, the interval display will flash. Choose an interval of two minutes or more.
• Full-pressing the remote shutter-release button has the same effect as full-pressing the shutter-release button on the camera, starting interval mode photography.
• When the camera enters interval mode, it will either take a picture and then begin the count to the next photograph (Interval Mode A), or begin the count to the first photograph (Interval Mode B). The Interval indicator in the LCD display will flash while interval mode is in effect.
Ending Interval Mode Photography
• Half-pressing the remote cord shutter-release button while an interval mode is in progress stops the interval photography.
• Photography will also stop should you run out of available space on the compact flash card; In this case, the number of exposures remaining displayed in the LCD panel will be 000.
The MC-EU1 has a feature that when the zoom button is pressed twice in rapid succesion, the camera will start zooming until this function is cancelled by pushing the button a third time. If this function is not cancelled, no other function is possible with the MC-EU1. If the MC-EU1 does not respond as expected please ensure you have not activated the zoom function.
Jan 02, 2010 | Nikon MC-EU1 LCD Remote Control
Put 4GB card in - OUT OF MEMORY appears.
I have nikon coolpix L5, i just brought a 4gb memory card that's supposed to be compatible, but when i go to take a picture it say You cannot use this card?
Jul 11, 2009 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5700 malfunction
It sounds like the Function (FUNC) button is stuck. Actually, that's what is supposed to happen if you press the FUNC and then turn the wheel... but it's not supposed to stay that way after the FUNC button is released. Try tapping the FUNC button to see if it releases.
Nov 17, 2008 | Nikon Coolpix 5700 Digital Camera
Finding cable release for Horseman Digiflex II
I have a digiflex II as well. I use use the remote cable release from my Fuji GX680 camera on it and works fine. They use the same cable plug.
Nov 15, 2008 | Horseman DigiFlex II Film Camera
Nikon coolpix 5700 shows no memory left after purchasing a new card & batteries
The largest CompactFlash card that Nikon approved for the 5700 is 256MB, which is what I'm using in my 5700. That's small by today's standards and you probably won't even find it in stores. I see some web sellers have 256MB cards for only $6 or so. Other commercial card sellers on the web claim that the 5700 will handle CF cards up to 1GB capacity. That's what I might try since online they're selling for as little as $8 plus shipping. Given that the 5700 was introduced in 2002, any cards bigger than 1GB probably won't work.
Jul 21, 2008 | Nikon Coolpix 5700 Digital Camera
Batteries
Hi
One of the original Nikon batteries would be best, but more expensive. There are generic batteries costing less and it may work if you get a couple of them, they do a good job as well. Not sure which country you are in as i may have been able to amke a suggestion of a supplier for both.
regards
Jul 17, 2008 | Nikon Coolpix 5700 Digital Camera
Blurry images on a Coolpix 5700?
This camera was in the time when the ccd had problems.
http://www.nikonusa.com/email_images/nikonusa/service_advisory/coolpix.html
Call Nikon concerning your camera. You can send it to them, they will estimate it, and may repair it for free if it is the ccd problem.
Apr 05, 2008 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5700 - won't turn on
Look in the user manual.It should say something about that if not call tech assistance at 1-800-nikonus. Oh by the way there is a user manual here for ya if you need one in the tech specs of the camera. simple click on the nikon COOLPLEX 5700 DIGITAL AND IT WILL TAKE YOU TO A TECH PAGE WHERE YOU SCROLL DOWN TO FIND IT. Good Luck
Apr 10, 2006 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
201 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
