Question about GE Profile Spectra JGBP90 Gas Kitchen Range
How do I change an orphase from a natural gas to propane?
The oven was set up for a natural gas but I need it for propane. The range is fine and has been fixed but the oven did not come with a new orphase for propane. I have spoke to several appliance people who tell me this oven can be changed with a cresent wrench. PLEASE HELP. I have been told there is no part to order.
  • 1,543 Answers
If you have converted the burners and the regulator, all you have left to do is the oven and broil burners. (for self clean oven model you posted under)
Let's do the broil burner first. Open oven door and look up at the broil burner. At the back of the oven you see the tube that the gas flows through to get to the burner. At the base of this tube is an air shutter opening, and right there you will find a brass nut with a hole in the center of it (the burner's orifice). Use a 1/2 inch wrench to turn the nut three full revolutions clockwise looking at it from the burner side. It is easier to turn it twelve 1/4 revolutions.
Now, do the same to the main burner by removing the storage drawer, remove the one screw holding the metal plate so you can get at the base of the burner, and do the same to that orifice. Do not over tighten the orifices.
Posted on Nov 25, 2008
I have propane. Is my range set up fpr natural gas or propane and do i need to change. I'm having issues with my oven
without knowing your model number or mfg it's tough to say 4 sure but i can say that most common mfg do offer a propane conversion kit to use there gas stoves on bottle gas , most often it's a new regulator to install
Jan 08, 2015 | Kitchen Ranges
I have a Sears Kenmore Elite 790 hooked up to propane .. is it ok to have it hooked up to propane or is this over for natural gas only?
Kenmore Gas ranges can be used with Natural gas or Lp. They come from the factory set up for Natural gas so if you want to use Lp it needs to be converted by you or your gas company. There are several adjustments that have to be made and some ranges require orifices to be changed. Your installation manual tells how to convert it but if you're not sure about doing it you would be better off the call the gas man.
Aug 28, 2011 | Ovens
I have a Frigidaire Stove, Model # FGF316ASA. It was changed from propane to natural gas. The oven works well. The burners, however, will only burn a low flame. Is there a solution for this?
When converting an appliance from propane gas to natural sometimes a technician will drill the orifice to a larger size rather than replace the orifices. Either way is fine, but sometimes the orifices don't get drilled to the correct size. The regulator must be on the propane setting if it is a convertible regulator. If your oven is working fine.... the top burner orifices probably need to be checked that they are the correct size. A simple fix.
Tom
Aug 11, 2010 | Frigidaire FGF316 Gas Kitchen Range
Stove converted from natural gas to propane burners work fine but oven has about 8'' of yellow flame and comes up over diverter into oven. air shutter makes no difference full open or full close and...
The orifice, holes that the gas comes out to the burner)s) for the oven was not changed out.Gas is measured in inches, Natural gas runs abourt 5-7 inches of presure, Ppropane runs about 12-15 inches of pressure, much more. The orifices, holes that the gas comes out, for natural gas, are larger to send more gas to burner. With propane, the orifices are WAY smaller, because the pressure is much higher.
Mar 30, 2010 | Kitchen Ranges
Natural gas to propane
changing from natural to propane requires different jet sizes and repositioning of the air mixture shrouds
working with gas is not in the domain of diy as you have found out so get in a gas fitter to do the conversion properly with out risk of an explosion or fire
Jun 20, 2017 | Vulcan VG36 Gas Kitchen Range
Switched from natural gas to propane now oven flames up sides how do I fix? Model#362.75571691
Propane and natural gas are two different fuels and require adjustments to the appliances to which theye are connected. Typically, when converting to propane from natural gas, a pressure regulator and a change in gas jets are required. This is because propane has a different heating value (hotter) and behaves differently.
Also, propane doesn't burn as cleanly as natural gas so after you have made the hardware changes, if you start to smell something in the kitchen, you may need to crack a window slightly to provide for better venting.
Please be careful
Jan 01, 2010 | Kenmore Kitchen Ranges
Ge propane kitchen range changed to natural gas.can't get the ove
Hi, Did you flip the cap on top of the regulator? As far as adjusting the bake/broil orfices, all you will nee to do is turn them 2 full turns counter clockwise. Start the oven and watch the flame. It should have blue tips as much as possible.
You might have to raise or lower the orfice adjustment as needed.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I purchased a new natural gas range a couple years ago for our cabin. I need this range to use propane.can this oven be changed to use propane instead of natural gas?
should be able to change orifices to propane. some ranges offer these on the back of the stove or you can buy them at a local parts dealer. take your model # with u when you research a part
Jun 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
CONVERTING TO PROPANE FROM NATRURAL GAS
just need to change out orifices in gas line natural gas company should have new ones in stock
Aug 23, 2008 | Tappan TGFS_63 Gas Kitchen Range
Fumes
are you using propane or natural gas you may need to change the setting for what one your using in the back it will have a bag filled with new orifices you may need to change them out plus on the regalator you can switch to natural / propane
Aug 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
339 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
