Question about HP Vs17 17" LCD Flat Panel Monitor
HP vs17 monitor power button flashes blue but screen stays black.
Screen stays black but power button flashes blue. Any ideas?
  • 6 more comments
  • ROLC Nov 27, 2008
    I have the same problem and I tried putting off my Monitor, unplugging power cord and the VGA cord for 1min and reinserting and restarting my PC but that does not work. Any other ideas? Your help is very well appreciate. Thank you.
  • shandly001 Dec 25, 2008
    Exact same problem,black screen with blue flashing light.Unplugging every plug and waiting makes no difference.Any other ideas out there?
  • tch647 Jan 12, 2009
    HP Vs17 power light switch keeps flashing green then amber but screen stays black.
  • Anonymous Jan 20, 2009
    I have even tried a different monitor and it still does the same thing after starting again after cords have been pulled - paused - reinserted - then starting the tower before the monitor.... Anything ? Anyone ?????
  • fhg1282 Jan 23, 2009
    I have the same problem and tried using a different moniter for awhile. When I went to try this one again, it wouldn't even turn on.
  • pierrer Feb 25, 2009
    I have the same problem and I went to a friend and tried the monitor with his computer and it did not work. I hooked another monitor to my computer and it works fine now. Definitely it has to do with the monitor and I have to find out if it can be repaired now.
  • Anonymous Apr 06, 2009
    Having the same problem, any one have any suggestions besides the power cord check and total reboot?
  • Anonymous Apr 17, 2009
    same issue here.. anybody can help us please? I am about to buy another monitor but I would really like to know if this one still have a chance to be fixed.
V sonic monitor problem is no analog msignal
Posted on Apr 07, 2009
  • 153 Answers
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Posted on Nov 25, 2008
HP vs17 (PK657AA) problem: the image is displayed for 3 seconds
first try entering VGA mode in the startup menu. u can get the startup menu by pressing the F8 key immediately after the POST screen. if the screen stabilizes try changing the resolution to 1024 by 768 which should work in normal mode. if that doesnt work then the monitors internal bulbs may be burnt. an electrician may fix this problem for you.
Nov 18, 2011 | HP Vs17 17" LCD Flat Panel Monitor
When i turn it on the green light flashes but the screen stays black i have hp Vs17d
remove themonitor cable from the cpu and see wether there is no connection mentiond in the screen if you have so then remove the cover of the desktop and remove the ram and clean them and still the cpu is not working then change the ram
Oct 29, 2011 | HP Vs17 17" LCD Flat Panel Monitor
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did' power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
Power button is on (blue) but no display. If you
Try to change the screen resolution and frequency setting of your graphic card.
1. Restart your PC
2. Before getting into splash screen, press F8 frequently
Choose enable VGA mode by pressing up arrow and press Enter, wait until finish loading. Now the display looks bigger, change the screen resolution to best fit to your Monitor (normally 1360X800). DO NOT CLICK OK>go to advance tab> Monitor tab, choose 60Hz for screen refresh rate, NOW you may KLIK OK
Apr 10, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor does not turn on
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what goes wrong:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Apr 08, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Screen does not go on.
You may have backlight inverter circuits failure or power supply failure, look inside for bad capacitors in the power supply first since it is easy to do, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps, inverter, or lamps:
Mar 15, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Black screen, flashing blue power light
Chek the RAM of your system. Clean the slot and re-fix the ram. If the problem not solved replace the Ram
Jun 17, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
Aug 27, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Not working.
Did you install the software for the monitor? If you do not have the disc, You can download the driver here:
If you have any further problems,let me know. Thank You for using Fix ya!
Aug 23, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
2,027 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
