Question about RCA VR702HF VCR
Tape plays for a while then stops...
When I insert a tape into this VCR, it plays for about 30 Seconds then stops, ejects, and won't play any more. Any ideas? A local guy suggested it could be the tension-er pulling the tape too tight, and that it just needed to be loosened.
  • Jim Sleggers Jan 02, 2007
    This happens with every tape.
  • 4 Answers
Play it till it stops when it ejects see if you can spin the wheel with your finger or if it feels like it is hung up try a different tape se if the problem goes away if it does not go away sounds like you need to get the heads cleaned or get a new VCR or better yet get a dvd player/recorder you can get one with a dvd/vcr and record your vhs on to DVDs
Posted on Jan 02, 2007
VCR won't eject tape
unplug VCR take the top off about 4 screws or more I would say you willmbe able to see that tape is wound round inside you should be able to remove it .
Mar 16, 2013 | Heating & Cooling
VCR won't record, just ejects tape
You have not mentioned the make and model number of the vcr. Any way the problem is due to end sensor or related circuit. End sensors are photo diods which you can check the shorting with a multy meter.
Jan 13, 2013 | Emerson Televison & Video
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Magnavox vcr/dvr. insert vc tape, machine loads and plays tape for about three seconds then stops and ejects tape. tape will not stay playing. thanks, larry
Mine does the same.It's basically junk.A new VCR/DVD player goes for around $80.If you were to call to ask about getting your VCR repaired,they would tell you that it is FAR cheaper to simply purchase a new one.Same Magnavox I bet almost too.model # for mine is MWD 2206.Labor alone is easily at least $60/hour and it would take that just to disassemble and reassemble the VCR section just to get at the problem.Greg
Feb 10, 2011 | Televison & Video
Tape ejects after playing for about 30 minutes
it could be dirty pinch rollers causing the tapes to tighten and be ejected. try fast forarding the tape to the end and rewinding. if this does not cure the problem, run a wet cleaner tape through.
Mar 05, 2010 | Emerson EWV403 VHS VCR
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Open Questions:
See all RCA VR702HF VCR Questions
Televison & Video Logo
284 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
