Question about Protron PD-DVR100 DVD Recorder
PD-DVR100 DVD Tray will not open
The DVD tray on my Protron PD-DVR100 will not open. When I push the open button on the front panel the word 'OPEN' flashes on the display but the tray will not open no matter how long I wait. If I press it again the display reads 'LOAD'. But still the tray does not open. I can get it to toggle between 'OPEN' and "LOAD' if I continue to press the button. I've tried several things including unplugging the unit for an hour and then plugging it in and trying it again. This is the third time this has happened. The first two times it seemed to fix itself. The Protron 800 number provide only the very basic advice for routine problems. This is not a routine problem. Any advice? Thnx, Mikey Joe
Open the DVD, looking from the top you will see to the left and to the front of the DVD a little black (the teeth) gear, with a small screwdriver make the gear turn (towards tou), then you will see a white plastic piece (like a hand saw) coming out, at this moment the tray will begin to open, gently pull the front of the tray and the DVD will come off very easy. This will take about 5 minutes or less. Believe me this will work, I was about to take my baseball bat and practice my swing with the DVD.
Posted on Oct 11, 2008
  • 3 Answers
If anyone does throw out their Protron DVD Recorder, I will buy the manual and/or the remote from you. E-mail me at: emailBillNetter@yahoo.com if anyone can help me out with either item. Thanks, Bill Netter
Model # PD-DVR100
Posted on Jul 15, 2008
UNPLUG and COOL.
Try unplugging the unit and letting it cool for a while (several hours). I know for a fact that if my unit heats up too much the tray will not open. If I unplug it and let it cool the tray will open.
Posted on Jul 14, 2008
  1. Make sure the unit is connected to an antenna.
  2. You may have a loose internal drive cable. If the cable from the DVD drive going to the circuit board is not fully seated, the unit will power on but the disc drive won't open. This is fairly easy to check, but you have to remove the screws and take the top of the case off. The inside is very roomy. If you open up the unit, and are facing the front of the unit, this circuit board is to the right of the DVD drive. It's connected by a cable similar to a computer IDE cable. Make sure it hasn't come loose.
  3. I think these units have a heat problem. I mounted a computer CPU fan above the the heat sink on the circuit board, and cut a hole in the top for ventilation. This helped a lot. You can also try leaving the top off to see if this helps.
Posted on Jul 01, 2008
I am having the same problem. Sometimes, unplugging the unit works, but only after multiple attempts. However, recently, it didn't work at all after several days of unplugging and replugging the unit in. After doing some research with other brands experiencing the same problem, some of the solutions suggested pressing the open button and record button @ the same time. I tried it, and It didn't work; however, when I pressed the center of the "source/record" button, it opened! Thank goodness, because I had a DVD in the drawer and thought I was going to have to tear the thing apart to avoid buying it from Blockbuster. Hopefully, my discovery will work the next time I experience the same problem. If not, it's going in the garbage!!!
Posted on Jun 05, 2008
I am having the same problem of ejecting the disc. The only thing I can think of is to open the top cover and unscrew the part that holds the top part of the disc. Then the disc can manually be taken out. Maybe the eject mechanism will function again once the disc is removed. You just need a special type of screwdriver.
Posted on Jan 15, 2008
Perhaps the "reset factory settings" function is active. The door won't open until you go through the set-up sequence fully. My problem is one day I had a picture and now I don't I checked the cables and I am hearing sound. I connected several video outputs to my TV and I get blue screen on all of them. What's up with that? I am glad I only paid $60 for mine however the protronusa website is no longer available. I don't know if the toll-free still works or not... I'm going to try the unplugging thing and see if that fixes me.
Posted on Nov 19, 2007
I have the same DVR100 i have been trying to get my door to open for at least 2 months now without any solutuion. I bought it from QVC and am very uphappy with it. I am glad I wasnt watching a rented DVD
Posted on Nov 16, 2007
Hi Mikey We are having the exact same problem with our recorder. Don't know if it will work for you, but we turned it off and while it was saying hello, my husband kept pushing the open button and it finally opened. We recorded a movie last nite, and it wont do anything, just keeps flashing PrOce on the player screen. I called the 800 number and he told me to unplug it too, that it would reset itself. It's pretty bad when you spend $300 on something and it only has a 90 day warranty, and then they expect you to just take it to a repair place and have it fixed yourself. We will never buy a Protron product ever again. Guess we just have to go buy a new one, since they wont help on this one. If anyone else has any suggestions, please help us out. Thanks, Becnfiat
Posted on Apr 08, 2007
Tip
Protron DVR100 Manual Download
Download Protron DVR100 Manual
Have you lost your Owner's Manual for your Protron DVR100 DVD Recorder?
Would you like a digital copy of the Protron DVR100 DVD Recorder Users Guide for easy searching of terms and quick reference?
The Protron DVR100 DVD Recorder manual is available free in pdf format, just follow the link below (& Click FREE):
I hope that helps.
________________________________________________
on Jun 14, 2010 | Protron PD-DVR100 DVD Recorder
What is the att uverse remote code for Protron PD-DVR100 DVD Recorder
hi,
Do you mean AT&T U-verse remote. then the code for protorn dvd plyaer is 2149
ok
Jan 16, 2011 | Protron PD-DVR100 DVD Recorder
No power on protron pd-dvr100
There is something you can try first.
With leaving something like this condensation tends to form on the circuit boards.
To remove this put the dvd into a warm room, plug it in for 2 hours, and see if thats cured it.
Nov 02, 2009 | Protron PD-DVR100 DVD Recorder
I need a remote for my dvr
tengo un pioneer dvl-dv888 no abre la bandeja , podria alguien ayudareme gracias
May 26, 2009 | Protron PD-DVR100 DVD Recorder
I am looking for an owners manual PD DVR100 Protron recorder: Model # PD DVR100
Google is a help, but sometimes you gotta pay for these things.
http://www.retrevo.com/support/SpectronIQ-PD-DVR-100-DVD-Players-manual/id/926dj289/t/2/
Apr 15, 2009 | Protron PD-DVR100 DVD Recorder
Change region code as not region free
Turn on unit and put into TV/Tuner Mode
Press “Eject” button and confirm tray is out.
Press “repeat” button 3 times on remote
Press “0” button to make Region Free
When you see “OK” on screen, press enter or repeat on remote
Turn unit off
When you turn unit back on, it should be set for “Region Free”
Jul 29, 2008 | Protron PD-DVR100 DVD Recorder
Protron pd-dvr100 dvd recorder
I need get manual to protron 100 dvd recorder
thanks
Jul 11, 2008 | Protron PD-DVR100 DVD Recorder
Dont kno how to record
Connect your cable from the wall to the RF IN on the back of pd-dvr100
Connect your RF OUT on the back of your pd-dvr100 with a coaxial cable not included to the RF IN on your cable box
Connect the red, yellow, and white RCA Cable to the front or back of your TV
and to the audio out and video out on your pd-dvr100
Press the SETup button on your remote use the up and down buttons to select the channel scan sub menu
select IRC for your tuner input source
select scan and press Enter
The recorder can now record all scanned channels onto your dvd+r when you press the record button
I only got it to record the scanned channels.
The good thing is you can record on another station while you are watching a show on your cable box.
Aug 19, 2007 | Protron PD-DVR100 DVD Recorder
Protron PD-DVR100 DVD Recorder Logo
376 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
