Question about V, Inc. Vizio P50HD Plasma Television
NO PICTURE My vizio P50HDM popped and went shhhhhhhhhh1
  • 5 more comments
  • dzanzie Nov 25, 2008
    The Vizio P50HDM POPPED AND WENT SHHHH NO PICTURE.The power light is on but can not get a picture,please help.
    Need more help,thanks!
    Does anyone have an pictures? What do I have to do to fix this television? I expected to be told
    how to fix this when I agreed to pay for this
    information.
    Ok,the fix is the same as the Polaroids,is that right?
    I know that caps get bulged on to. how do I know if a transistor is bad,discolored are is there a why to test it? THANKS.
    Thanks to every one,have a good night!!!
    Thanks to every one that helped,have a good night.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, the unit must be opened up for a look and see. Pls keep in mind that this is a plasma monitor and repair could and would be challenging even for seasoned technicians. This of course would require a more than familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
If you are that comfortable working with electronics and would venture a DIY, foremost to check would be the CTRL board and the Z SUS board. The power supply would seem to be working since their is still the standby power indicator. This could also be verified by a clicking sound, that of the relay engaging and dis-engaging.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 25, 2008
  • 153 Answers
There should be a burnt component, open cover and check for any visiul burnt components, replace the burnt components if you can or ask a technician to do it for you.cheers.
    Sergeant:
  • 291 Answers
Solder all the joints on the board so as to get rid of any loose joints causing this problem. Also check for faulty transistor or capacitors and replace them.if u need to know what capacitors look like just look out for capacitor images in google.
thanks.
    Sergeant:
  • 276 Answers
Open the device and check if any of the capacitor on the board is bulged or torned out.if u find any of them ,replace them with new ones of same value.the tracking will get complete and ur tv will be ok.
  • smarttech Nov 25, 2008
    the drum like small things on the board are to be replaced
    yes u can say.if u need more help feel free to ask ur queries.
    Brigadier General:
  • 3,614 Answers
This be a output transistor shorts out. Due to the nature of the type of power supply, the main fuse won't burn out. The switching power supply will shut down because of the over current condition due to the shorted output transistor.
  • 89 Answers
Yep, Something has blown. We had a Monitor do this... Didn't bother for support, because it was kinda old, But if your still under warranty, you shouldn't have to pay for repair.
  • V, Inc. Master
  • 19,396 Answers
That is because one of the internal components has blown.
  • Ginko
    Ginko Nov 25, 2008
    When that happens it is usually a capacitor or another component that has blown, the component must be replaced by a technician,
    call the number listed on your owner manual to get support.
I have a Vizio p50hdm while watching heard a pop noise and tv went out cant turn back on.I replaced main board and power board and still doesn't come on any Ideas?
The power amplifier chip (which goes "pop" when it goes bad) may be located on the board where the IR sensor is. Sometimes (but not always) you can make the TV come on by holding the power button in _until_ the TV comes on. But that usually only works when the chip is "going" bad. If you heard the pop, it's probably shot. Also, check for a fuse on _any_ of the boards, and possibly a main fuse at the back of the TV.
Mar 09, 2016 | Vizio 50" p50hdm high definition...
Vizio P50HDM Plasma
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jun 23, 2014 | Vizio 50" p50hdm high definition...
Picture went out on Vizio P50HDM
Check you voltages before just swapping out boards. Although a YSUS is common for no picture, so is your upper and lower Y Buffer boards or the panel itself. Check youe -VSC voltage. Does it look like it is being loaded down? If so then your YSUS is not the problem. You can run the set with just the upper or lower Y Buffer boards untill the load is gone. That will let you know wich board to replace.
Jun 20, 2012 | Vizio Televison & Video
Picture went out on p50hdm Vizio Plazma tv after loud POP
It's either the backlight lamp or backlight inverter is busted due to a power failure or fluctuation. Here's how to determine which is which:
  1. Grab a flashlight.
  2. Turn on the TV.
  3. Shine the flashlight onto the screen.
  4. If you cannot see any display even a faint one, the backlight inverter is dead, else the backlight lamps are busted.
  5. Replace which ever is the culprit.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vertical lines on 50 inch plasma
Hey did you ever get rid of the "racing stripes"?? my P50HDM now has the same problem...i know this is askin for spam but if anyone has the solution email me at ppackratt3838@yahoo.com thanks
May 22, 2008 | Televison & Video
V, Inc. Vizio P50HD Plasma Television Logo
Top V, Inc. Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
rostit
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
