Question about RCA HD52W58 52" TV
Tv some how has got zoomed in at 16.9
Do not know how it got this way and I can not find my owners manual. I can get the zoom option to come up, but can not seem to get it changed.
  • 1,030 Answers
To change the fomat push the left or right arrow keys
Posted on Dec 06, 2008
How to resize picture on a magnavox mwc20t6
Look for a setting called Aspect Ratio. It will include options like 4:3, 16:9, Zoom 1, and Zoom 2. Then click through the options to select the correct one for your program. Usually older SD programs will use either 4:3 or Zoom 1, while HD programs will be set to 16x9 for Widescreen hi-def viewing. There should be a button on your remote labelled Aspect Ratio or Picture that can toggle through these image modes.
Nov 26, 2014 | Philips Magnavox MWC20T6 TV
Zoom movie
From page 75 of the manual: "The zoom is not available when shooting movies. Be sure to set the zoom before shooting."
Feb 07, 2013 | Canon Powershot A3400 Is 16 Megapixel...
I have a 50 inch plasm tv and can't seen to get the picture to fill the screen it has borders on both sides
Maybe your screen is configured to display 4:3
To see the others options
Turn on the TV
In remote control press button ARC
You will see
Zoom 1
Zoom 2
Choose the better image and depress.
I recommedn use 16:9 Wide screen.
Vote If the information resolve the issue
Sep 14, 2011 | LG Televison & Video
I can't get the zoom to decrease on my tv. is it a problem with the tv, or the cable box?
This is the TV. Look for an aspect ratio or picture size or other wording button on the TV's remote control and READ your TV owner's manual. John
Jan 28, 2011 | Philips Televison & Video
The left side of the LG 42" plasma TV has no
try to check the aspect ratio and input source to make sure they are correct. for the aspect ratio, make sure it is set either at 16:9 ratio or try the zoom options. if it is set at zoom, you can move the screen left to right or up or down through the zoom settings. make sure you are also using the correct cable. hope this helps
Nov 25, 2010 | LG 42PC3D 42 in. Plasma Television
40 in LCD Proscan TV, Horizontal pic too wide, adj?
just look at the owners manual of how to adjust the picture
Jul 23, 2010 | Proscan 42LA45H 42 in. LCD TV
TV zoomed in
Look at your remote or On-screen menus for ratio settings. The remote might say zoom or ratio. The menus will probably have it under video and then Aspect Ratio. You'll probably need to hit go through several settings to get to the correct ratio. (some choices are 4:3, 16:9, Full-screen - the best choice depends on the set and the source video)
I hope this helps.
(my remote (slightly different TV) has the zoom just above mute so I hit the wrong button often.)
Apr 24, 2010 | RCA 36V550T 36" TV
Zoom control
Use the menu key on the set it has a size selection in the menu set it on widescreen or 16:9 I suggest buying a new original remote as even a new RCA universal remote may not have the ZOOM or aspect control on them.
Aug 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture larger than screen...
If you go to 4:3 mode and the picture is still cutoff then i would assume the tv has a problem with the horizontal or the pinchusion correction circuit . This would be the only two areas that would cause this problem . Check the format section of your menu to make sure it is not in zoom mode or otherwise if it is not then you have a problem with one of two above mentioned circuit problems . Good luck
Feb 01, 2008 | Sanyo DS31520 31" TV
Zoom in and zoom out
Try looking in the menu under PICTURE. see if there is picture size adjustment for picture size eg 16 x 9 4 x 3 normal wide.
Nov 10, 2007 | Bush 2871NTX 28" TV
RCA HD52W58 52" TV Logo
54 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
