Vmm32.vxd problem on windows millennuim edition its saying load windows loader dont knoe it please help have no disc omputer given to me thanks
  • 94 Answers
Just go to start button goto run type regedit and press ctrl F and then type vmm32.vxd and press find and if the file that type is showed delete the vmm32.vxd and press F3 to search again the if you find another file like that again just delete it and its finished restart your computer.
Posted on Nov 25, 2008
Were can I get a free recovery disk for windows\system\VMM32.VXD and download it
It wont be free but it will be cheap. Call emachines and request an ew set of recovery discs.
Mar 20, 2011 | E-Machines etower 633ids PC Desktop
I deleted windows\system\vmm32.VXD on my etower633id
You must either recover that file from a backup, copletely reinstall windows, or use the Windows Recovery disk that came with your computer to repair the partition.
It doesnt want to start it says what im describeing.
From http://support.microsoft.com/kb/194679:
Cause:
This behavior can occur if the Windows\System folder is missing or renamed, or if the PATH line in the Autoexec.bat file is missing or does not include the Windows\System folder.
To resolve this behavior, use the appropriate method:
Method 1 loadTOCNode(2, 'resolution');
  1. At the command prompt, type: dir vmm32.vxd /s If the Vmm32.vxd file is not found, you must install Windows 95 or Windows 98 again. If the Vmm32.vxd file is found, note the folder in which it is located, and then continue with step 2.
  2. At the command prompt, type the following commands, pressing ENTER after each command cd windows
    ren folder system
    where folder is the folder you noted in step 1.
  3. Restart your computer.
Method 2 loadTOCNode(2, 'resolution'); Using a text editor (such as Notepad), edit the Autoexec.bat file and add or modify the PATH line so that it includes the Windows\System folder. For example, add the following line to your Autoexec.bat file: path=c:\windows\system
Hope this helps,
-LL
Mar 16, 2010 | Toshiba Satellite 2060CDS Notebook
Cd rom not working says..failure using the VxD loader please explain
check if the CD/DVD is recognised on the computer screen... If yes check if light near the tray glows... if not follow the steps very very correctly and carefully.... click start....on the RUN box (windows Vista )... type REGEDIT then In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\ SYSTEM\ CurrentControlSet\ Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318} In the right pane, click UpperFilters.
On the Edit menu, click Delete. When you are prompted to confirm the deletion, click Yes. In the right pane, click LowerFilters.
On the Edit menu, click Delete. When you are prompted to confirm the deletion, click Yes. restart check if the dvd/cd work....let me know the out come.... happy watching movies... thx
Jan 13, 2010 | Sony Computers & Internet
Hi... my problem is my PC cannot find a VMM32.VXD
You can find instructions on how to get around this issue here. You will need to be able to boot to a command prompt from a Windows Startup disk. When using these instructions, be very careful about the commands you enter. You must make sure you don't mistype anything since it could cause more problems.
Jul 07, 2009 | Microsoft Windows 98 for PC
Computer won't boot up
You Can Try Using The Safe Boot Option Or Obtain A Windows Xp Repair Disk.
Jan 17, 2009 | Computers & Internet
The following file is missing or corrupted; C:\WINDOWS\SYSTEM\VMM32.VXD type the name of the windows loader (e. g., C:\WINDOWS\SYSTEM\VMM32.VXD)
That is a special file, created during Windows installation. Every computer uses a different VMM32.VXD file, so you can't simply copy one from another system and expect it to work.
If you can't find that file by searching the system in DOS, you could wipe the drive and reinstall Windows again, or do a repair install, installing Windows on top of itself. That should force the creation of a new VMM32.VXD file, and that problem should be history.
If you DO find the file somewhere on the HDD through a DOS search, copy it into the Windows\System folder, then reboot the system.
Jul 23, 2008 | Computers & Internet
MIL-W1897L cannot install device
Not much of a solution, but keep uninstalling and re installing the driver cos win98 not very good for driver issues, i remember having to fiddle around with it with win98se also. Perhaps the device is recognised but not being installed because of a faulty slot or mobo fault. But personally I wouldn't go on-line with win98, would advise upgrading to xp sp2, much better with security and easier to sort out driver issues. Trying to forget Win98/SE, not very pleasant!
Oct 12, 2006 | Milan Technologies ShAir Access MIL-W1897L...
Computers & Internet Logo
65 people viewed this question
Alun Cox
David Payne
David Payne
