My remote won't start the fire in my vent free fire place.
It's unit FRC 0.584.004. FCC ID is: QFA-FRC584001. It goes with a DESA heating unit (vent free fire place).
  • 4 more comments
  • rksnavely Dec 01, 2008
    Not only does my remote not start the fire place, but now the fire place shuts off after only burning for a few minutes. So the manual part isn't working properly, either. Very frustrating!
  • g_m13 Dec 06, 2008
    My heater did the same thing. The shutoff problem was fixed by cleaning the unit. I pulled all the logs out and blew everything out with compressed air (air compressor with an attachment). The unit works fine except for the remote not working.
  • sharonlbeebe Dec 14, 2008
    I'm having the same problem, remote control isn't working. Fireplace will work with the manual switch.
  • scestaro Dec 19, 2008
    I have the same problem - the remote does not work - what is the problem!!!
  • gebm Jan 13, 2009
    MY REMOTE WILL NOT TURN ON MY FIREPLACE.
  • Anonymous Jan 27, 2009
    same problem! remote doesn't work most of the time. I changed the batteries a few times, what else should I do? buy a new one?
Mine did the same thing. What happens is when the batteries die and the remote sits, the remote loses its address. I found this link to the remote manual online. You have to locate your receiver in the fireplace insert. On the receiver there is some dip switch settings. Open up the link below and go to the appendix at the bottom and find your address of the receiver, mine was 005. Go to your remote and power on. Hit the up arrow until you are at the timer. Now hit the left arrow on your remote 10 times, this will diplay the address of the remote, mine was 000, change this number to match your address of the receiver by hitting the up arrow on the remote, I changed mine to 005. Now hit the left arrow again and this will take you out of programming. Power on your remote and should work, enjoy.
http://www.montigo.com/manuals/SIT_remote_controls.pdf
Posted on Dec 13, 2009
Gas fire place does not turn on with the remote but turns on only with the switch at the lower left corner. It seems to be a direct vent type gas fireplace. I wonder if the damper is not opening and the...
you have no damper, it was removed to put gas unit in. chcek batteries in remore and in RECEIVER, receiver is usually forgot about it is insdie the bottom door more than likely, the fan only comes on when unit is up to temp, it has a heat sensor on bottom of unit, check wires on a gas valve for remore receiver as well, usually go on top and bottom screws
Jan 29, 2010 | Desa International Wall/Window Air...
Desa International Self Venting Fireplace manuals
Try Googling (desa)(CGFB32CA)(manual) without parens.
Jun 30, 2017 | Ovens
Need instructions to my transmitter
I have the same problem. The company is out of business DESA Heating. I have been unable to find a solution. FMI bought part of DESA but can't get any help there either. 1-866-328-4537
Jan 18, 2009 | Heating & Cooling
0.584.004. FCC ID is: QFA-FRC584001 that is all I have to go off. My fireplace remote won't work and I can't use the fireplace to heat my home unless I turn it on and off constantly. Otherwise it is way...
I had the same problem. Just came home one day and tried to to turn the fireplace on and got no beep and no fire.Not sure if you still need this but I just finished repairing mine by trial and error. This might work for you so give it a try. If you look at the rear side of the receiver (left black box on the left side of the fireplace insert) you should see a series of white dip switches. I turned them all to the off positions and now my remote works.
Dec 19, 2008 | Heating & Cooling
I cannot get my remote to start up the fire place. It worked fine last year, but now it doesn't turn the fire on. It's remote unit FRC 0.584.004. Fcc ID is QFA-FRC584001.
There is batteries in the remote and at the loggs. Replace both. Mine had a black box under the logs on the left side tht had 4AAA batteries. Be carefull that the wiring is not pulled loose.
Nov 25, 2008 | Heating & Cooling
Pilot goes out after heating cycle
Check regulator on the unit.
Check pilot unit on the heater
use soapy water to check for leaks if see bubbles turn off main gas supply valve.
always turn off gas supply before any checks or repairs are made
when all else failes call your local gas provider to check heater and gas supply
Nov 22, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
FCC ID: BJ4-61WDB57ATX
This is a Desa (now Heath-Zenith) wireless door bell (remote chime). If you don't have the transmitter, then this receiver is quite useless.
http://homeappliance.manualsonline.com/ex/product/headline/m/desa/d/doorbell/p/SL%2B6150%2BRX/type/product_problem/
May 18, 2008 | Televison & Video
Heating & Cooling Logo
3,811 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
