Question about Canon EOS Rebel G 35mm SLR Camera
Shutter speed won't go above 200
I am trying to adjust the shutter speed in both the TV mode and Manual mode. As I turn the dial it will allow me to adjust the shutter speed up to 200 and not past. I have tried to increase the ISO but the shutter speed still won't go past 200. Any help please???
    Scholar:
  • 95 Answers
I have two possible solutions:
First, are you shooting with the flash up or an external flash connected to it? If so, the camera likely needs to synchronize at 1/200 or slower otherwise it won't be able to take a full photo. As a safety feature to prevent that, many new cameras just restrict the ability to pick a faster shutter speed.
Second, if its not related to the flash, it might be related to the mode you are using. Turn the camera off the automatic modes and put it on an all manual setting. Change the ISO to 400 or so, got outside and aim up at the day's sky, put it on manual mode and then adjust the shutter speed. Open up the aperture on your lens all the way (turn it to the smallest number). Now adjust the shutter speeds. It should be able to go past 200 now.
Posted on Nov 28, 2008
Now what?
Nothing is going on. Your camera is working as designed.
Most cameras have an upper limit on the shutter speed when used with flash. This is called the flash sync speed. At speeds higher than this the shutter is never opened completely, and as a result you would get only a narrow slit of a picture.
Usually this is not a problem since the exposure is determined almost exclusively by the flash and the aperture. Any action is caught and stopped by the brief flash, not the shutter. The primary reason for controlling the shutter speed is to use a slow speed to allow the background to expose.
Your camera may have a special high-speed flash mode that fires off multiple flashes coordinated with the shutter movement. Since you didn\'t say what model Canon camera you\'re using, I can only suggest you check the manual.
Apr 26, 2013 | Canon Speedlite 430EX TTL Flash
Cant set shutter speed past 200
Is the flash turned on? The camera won't let you set a shutter speed faster than 1/200 when the flash is on.
Dec 08, 2012 | Nikon D3000 Digital Camera
How do you set the aperture and shutter speed independently
First, make sure you're in the manual exposure mode, not manual focus mode, as set by turning the mode dial to the "M" position.
In manual exposure mode, turning the main command dial should change the aperture, while turning the subcommand dial should change the shutter speed.
If the two command dials don't have the expected effect, reply to this post and we can troubleshoot further.
Feb 20, 2012 | Olympus E-1 Digital Camera
I'm having problems with the settings on my Canon EOS 400D. When I take pictures in AV mode I can get quality pictures but in TV or M modes the pictures always come out so dark even when taking them...
You need to understand the relationship and teractivity of aperture, shutter speed and iso. In Av mod, you choose the aperture and the camera makes thw shutter speed agjustment, In Tv mode, you set the shutter speed and the camera makes the aperture adjustment, In manual, you have to set both shutter speed and aperture manually. If the ISO mode is set to AUTO, the camera chooses the sensors sensitivity to light automatically. Change to specific ISO
(200-400 for daylight and 799-1600 for night). Take a picture in AV mode and note what shutter speed the camera chose. Then switch to TC mode choose the same shutter speed and see if camera chose the same aperture(f-stop) you chose in first shot. Change to Manual and choose same f-stop and shutter speed the camera chose for you in the other modes. Compare all three photos. They should be almost if not exactly the same exposure wise.
In Tv mode choose a dlowers shutter speed, In Manual choose a combo of slower shuuter and wider f-stop(smaller number). Read your manual.
Jan 02, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
I'm using a Canon EOS Rebel X S 35mm SLR What setting should i set my camera for a manual shutter speed?
If your camera is a Rebel XS you should have a dial on the top right with a series of letters and icons. To set your camera so you manually control the shutter speed turn this dial too "TV" (Time Value). This setting will allow you to select the shutter speed and the aperture will open or close to achieve the correct exposure. The "M" is (Manual) where you would select both the shutter speed and aperture "AV" is (Aperture Value) where the user selects the aperture they want and the shutter speed increases or decreases to obtain a proper exposure. The "P" (Program) mode allows the camera to automatically select the shutter speed and aperture
Dec 06, 2010 | Canon EOS Rebel XS 35mm SLR Camera
I am in the "s" mode for shutter speed priority and i cant change the shutter speed i use the scroll to get the arrow above the shutter speed on the view finder and from then i cant figure out how to...
Are you pressing the jog dial to save the setting? Here's what your book says:
  1. Turn the Mode dial to P, A, S, M, or C.
    The mode options are displayed.
  2. Use the jog dial:
    • Press the jog dial to open a setting.
    • Press the jog dial to save the setting.
    NOTE: Available options are white. Unavailable options are grey. Red options are out of range and may cause unacceptable image/print quality. Adjust the value higher or lower until it turns yellow.
Jun 11, 2010 | Kodak EasyShare DX7630 Digital Camera
Nikon D60 Digital SLR--Slow Shutter Speed
Your're probably using a flash with TTL disabled. So 1/200 is the highest sync possible with that kind of flash. Did you try removing the flash off the body and setting faster shutter speeds?
Apr 28, 2009 | Nikon D60 Digital Camera with 18-55mm lens
F-stop issues
See pages 36&37 of the manual.
If you haven't got one, you can download it here.
In M mode...
Turn the selector dial to adjust shutter speed.
Hold down the AV+/- button (top-right of rear screen) and turn selector dial to adjust aperture setting.
As for Av mode, this is perfectly normal that you cannot set the shutter speed. Av mode means that you decide on the aperture setting and the camera (not you!) decides on the correct shutter speed.
Hope this helps,
Matt.
Mar 21, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
D 80, controling shutter speed
dear hydet
use 'Program Shift'. This will change the values for both aperture & exposure, but keep the overal exposure value correct. Eg if the standard values are 1/60th of a second at f5.6, then rotating the dial in one direction will change the parameters (first) to 1/30th & f8, etc, and turning it in the other direction will change them to 1/125th & f4.
oke, post in me back
thx
cropp
Mar 16, 2008 | Nikon D80 Digital Camera with 18-135mm...
Canon EOS Rebel G 35mm SLR Camera Logo
289 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
