Question about Wilton 17202 8" Bench Grinder
Grinder starts and stops on startup
Grinder powers off at start up for a fews seconds then starts again gets up to speed and stays on, it does this on/off sequence 2 or 3 times. This does this 3 out 4 starts. One the odd occasion it will start up normally.
Voltage supply good 116v, wires and connections all good start/stop switch contact good. Once the grinder is running the probelm goes away which in turn eliminates connection problems.
Capacitor faulty?
    Sergeant:
  • 359 Answers
If this is a cap start motor and not a centrifugal start run motor then bad cap is good place to start
Posted on Dec 03, 2008
Furnace won't stay lit. Intertherm Model M2RC-080A-16BN. Ignightor glows, flame starts and after a few seconds the flame shuts off. Then it starts the cycle again. It goes thru this cycle a fe
It sounds like the flame sensor is bad. If thats not the case you may need to replace the control board. You should make sure the flame sensor is directly into the flame.
Nov 20, 2014 | Intertherm Heating & Cooling
My treadmill runs for 9 secons and stops and shows E1
Ok. So the first thing to try is to calibrate the speed.
You do this by doing the following:
  • With the SAFETY KEY in place, hold the ELEVATION UP and SPEED DOWN buttons for five seconds. The console will beep twice, "ENG0" will appear in the Distance window, and a number will appear in the Elevation window.
  • Press SELECT until "ENG3" appears; this is for Auto-Calibration.
  • Press START to Auto-Calibrate.
  • The treadmill will calibrate minimum and maximum speed, and minimum and maximum elevation. When Auto-Calibration is complete, the treadmill will reset to User's start screen. This process takes three to five minutes.
Make sure there are no errors. . .and that the speed goes from super slow to super fast and then stops. . .. if it stays slow. . or stays fast. .or error code appears during calibration, there is a problem.
If after a good calibration sequence, if it still does the stopping and E-1 after 10 seconds. ., then you need to (Power off and disconnect treadmill). . .then unplug the speed sensor from the lower power board, blow into the connector on the wire, and add a little contact cleaner spray to the connector on the board.
Recap: If it actually runs. . .but stops after a few seconds. . but the calibration runs and passes fine. .. .more than likely it is a speed sensor misread or a faulty speed sensor.
Sep 30, 2014 | Triumph 400T Treadmill
1997 buick skylark temperature sensor location
the radiator fan gets the power from a relay that is energized by a signal from the ECM that in turn gets a report from the coolant temperature sensor
AT this point I would be thinking that there is considerable resistance in the relay
you say the fan works a bit so the temp sensor is reporting toe the ECM which is turning the relay on but power is low from there
replace the fan relay and see if the situation improves
you can test that theory by putting a meter across the wires to the fan when it should be working and reading the voltage available to the fan
if it is not 12 volts or better( 13.2-14 volts) it is the relay
Mar 13, 2017 | Cars & Trucks
Calling for a older friend> ac power outage happened within 30 secs of each other. Now computer comes on and begins startup showing screen but shuts down and starts up all over again and again
Unplug everything, wait a few seconds and retry startup. But it almost sounds like a virus or malware was uploaded into the computer. Also try startup in "Safe-Mode". Hold down key marked "F8" after pressing the power on button.
May 20, 2010 | Computers & Internet
Saeco: grinder stops grinding
Hello, This may be the solution for you: having removed the ceramic grinder to clean out the unit, one of the wires on the grinder had become removed (the "center wire") on the connector. The 2 outside wires were sufficient to give me the illusion that the grinder was connected correctly, however it would only run for a half second and then coast to an annoying stop.
Check all 3 wires that connect to the grinder and make sure they are making contact.
Jun 02, 2009 | Saeco Incanto Rondo
Kenmore Elite QuietPak 2 powers up and shuts off within seconds
I need the serial #, to better assist you
Thank you
May 12, 2009 | Kenmore Dryers
Generac Generator won't stay running
fuel problem, the float in the carborator is stuck, if you tap on the carborator bowl it will probably get freed up.if not take the bowl off and spray the insides with carb. cleaner.
Apr 11, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
Grinder setting stops at drip. Can't turn further to espresso.
Another suggestion is while the grinder is off, turn it up side down and rotate the bean hopper from coarse to fine a couple of times. This will clean out grounds that have gotten into the threads and it will prevent the bean hopper from not turning to a finer grind.
If you start to get a clog in your grinder, open it up to a coarse grind for a few seconds. The coarser grind will clean out the chute and then you can turn it down again while it is still grinding.
Dec 15, 2008 | Solis Maestro Electric Burr Grinder
Stuck grinder
make sure you not get any damp into the grinder. If you have damp in the grinder then it do not grind the beans.
/Mirran
Aug 30, 2008 | Saeco Incanto Classic Espresso Machine
Grinder runs with NO beans inside
Fill beans before they run out!
If you hear the grinder running empty, press the same button you pressed to start making coffe to cancel the current cup -or, if some beans were ground, stop the water a bit earlier to make a shorter coffe using the same method (press the button you pressed to start the cup). The auto-detect of beans missing is a very minor and largely useless feature.
Jul 29, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Wilton 17202 8" Bench Grinder Logo
340 people viewed this question
Top Wilton Grinders Experts
Tom Chichester
bob walter
bob walter
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Wilton Grinder Expert? Answer questions, earn points and help others
