Question about Power Acoustik SL2-2000 Car Audio Amplifier
The red light is on but there is power to the unit. no visible
Signs of damage or "burned up" look to it.
  • 631 Answers
If the red light is the protect LED, the amp probably has shorted output transistors. To eliminate other possible causes, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Nov 25, 2008
LG LDF6810ST won't power up there is power going to dishwasher
the main control board is fried from what you've described, you will need to dismantle it and remove the board (there will likely be visible signs of damage if there was a burning smell) relatively easy and cheap to replace
Jan 01, 2017 | LG LDF6810ST Stainless Steel Built-in...
No power
check out the regulators and horizontal output first, Then capacitors in the power supply. It could be a few things but those are first to check. If you would like I can send you a link where to purchase the service manual.
Keep me updated.
Thanks,
Lee
Jun 23, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Fix a samsung tv
If you have the 5.3 standby it's the (main board)....sometimes when the main is shorted you won't have your 12 volt supply...
Sep 12, 2016 | Samsung 50" Black UHD 4K LED Smart HDTV -...
Emerson lcd no power
There could be power supply problems even though there is no visible evidence.
Dec 01, 2013 | Emerson LC501EM3 50" 1080p 60Hz Class LCD...
LG55LH40 LCD TV wont come on
The set will need to be properly diagnosed. It could be a defective main board or power supply.
Sep 01, 2012 | Televison & Video
Tevion LCD4203ID, turned televsion on by mains plug, no power being received by television. Have tried different mains adaptor so is definately television. There is no red light or green light on...
Sir try to check the fuse in the power supply may be damage. Remove the back cover of your unit but be sure to unplug the unit from the main ac outlet. Then look for the fuse, if the fuse is defective, before replacing it observe if the fuse is totally burned if you see this sign don't just replace the fuse it indicates that it has a shorted parts in the power supply common parts are the regulator and bridge type rectifier, but if the fuse is just broken or still you can see the wire you can replace it and try to check if the unit will power up. Good day and best regards.
Sep 04, 2011 | Televison & Video
Unit does not stay on for more than 5 to 8 seconds. I opened the case and inspected the boards. All capacitors appear normal, there are no visibly burned components, No visible signs of heat. Unit worked...
from your suggestion, i think the problem is come from power supply unit, maybe the transformator was burned or damaged that make no power to the board
the other suggeastion is the power supply componen was damaged
try to check it
Feb 20, 2011 | Philips HTS3410D/37 700W DVD Home Theater...
No power. Fuses ok. Power transformer ok. Screw came out of circuit board, but no visible damage.
If a screw was bouncing around in the case it could have shorted something causing damage...
Make sure the power adapter is the EXACT one that is used for the unit.
Check the circuit traces from the power connector under a bright light. A short can sometimes "fuse" narrow traces burning them open just like a fuse.
If you haven't done so, check the power adapter with a meter to verify the voltage.
Sep 10, 2010 | Audio Technica ATW-R12 DIVERSITY RECEIVER...
GE Monogram ZV750SY Kitchen Hood
http://www.appliance-parts-warehouse.com
first examine part #166 and related parts for visible damage.
If the circuit board is burned out, then the above website is a suggestion for ordering.
Jun 14, 2008 | GE ZV750SY Kitchen Hood
No power on right hand side burners
WHEN THE SURFACE SWITCHES ARE IN A ROW ON THE CONSOLE, THEY ARE USUALLY WIRED IN PARALLEL FOR THE INPUT VOLTAGES(RED AND BLACK WIRES ATTACHED TO EACH OTHER). IF THERE IS A BURN OUT OF ONE OF THE WIRES, IT WILL AFFECT THE OTHER SWITCH INPUTS DOWN THE LINE.
TAKE OFF THE BACK PANEL OF THE CONSOLE AFTER UNPLUGGING IT AND CHECK FOR VISIBLE SIGNS OF WIRES BURNT. REPAIR OR REPLACE IF NEEDED. SOMETIMES, THEY WILL DAMAGE THE TERMINAL OF THE SWITCH THEY ARE ATTACHED TO. IF THIS IS THE CASE, THE SWITCH WILL ALSO HAVE TO BE REPLACED.
Mar 04, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Car Audio & Video Logo
99 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
