The phone line is fine, as the fax phone works fine, but the 3 cordless handsets all say "searching" and have for the entire day. I made sure everything is connected.
2 Other Users Have The Same Problem
Comment by samirv, posted on Jun 29, 2008
I have a problem with the phone keeping the line busy when I am not using it. If someone calls, it goes to a busy signal and I am not online. Now, the phone ran out of charge and I charged it up, but the screen is blank. Now the other handset did the same thing. The line is "occupied" and unplugging and plugging in is not working to "reset" anything.
I have no phone now.
Comment by steinbrass, posted on Feb 14, 2008
verge cordless phone. phones were disconnected for 6 weeks and when i turned it back on the base is working, (rings when call comes in)
handsets are continuously searching and no dial tone
Was this solution helpful? Show your Appreciation by rating it:
Comment by lolohayma, posted on Aug 22, 2007
It seem that the Main base is either bad or there is no power supplied to the base from the power adapter. Check to see if the charging light is coming on when you place the handset in the main base. If it is, then you have to replace the main base unit and re register the handsets to it. If it is not then most likely the power adaptor is bad. It is difficult to check the adaptor with out a meter but if you know of a way you can try it. If the adaptor is good and there is no charging light on the base when you place the handset in the cradle then the base definitely is bad. If you had a battery contact problem on the main base the extra handset would work and not say searching and the battery on the handset from the main base would run down from lack of charge as a result of the bad contact. Good luck
Post a New problem for Verge Cordless Phone
Email this problem
Can you Help with these Phones problems?
Information need to register a...
Verge Cordless Phone (V58ITAD)
