Question about Starrett Measuring Tools & Sensors
Checking level accuracy
How do you check a starrett 98 level to ensure it is adjusted correctly?
  • 3 Answers
You do not need to replace it. If it does not read the same when you reverse it, on one end there are a nut over and under the tube and plug assembly. Adjust those up or down until it reads the same.
Starrett Tech Support
Posted on May 15, 2009
  • 37 Answers
Hi, Easy fix. Put the level on any surface, note where the bubble is, Then turn the level 180 degrees and check the bubble again. If it's in the same place, Your level is perfect. If it's not, unfortunately you will need to replace it.
If this doesn’t work for you, please write back.
Posted on Nov 29, 2008
Starrett repair
I these punches are adjustable. Does the top turn or the bottom part turn. I use WD 40 or the likes to loosen mine up.
Jun 07, 2014 | Starrett 18a Automatic Center Punch
How do I adjust accuracy, I think it involves the screw on the left side.
Accuracy is not adjustable with the screw on the side of the gun, that screw would be the velocity screw and should not be played with unless chronographing the gun to avoid setting it at unsafe velocities.
If you'd like better accuracy there are 2 upgrades you can make. #1 is higher grade paint. The more round and smooth the balls are, the more consistent and tighter the grouping will be. #2 is barrel. The closer the bore matches the paint, the more consistent and tighter the grouping will be also.
May 31, 2011 | Tippmann 98 Custom Act Paintball Gun
How do I calibrate a Starrett model 449 depth micrometer?
Try the starrett web site. You can chat with them there about it. The adjustments are fair easy to do.
Nov 12, 2010 | Starrett 50443 12 Machinists' Improved...
My model 449 starrett depth mic turns hard, how can I fix this?
Are you aware of the lock nut that keeps the barrel from turning? There is a knurled ring next to the base that rotates to lock and unlock the barrel with a clamping action. Check that this is not causing the problem. Turn to left to unclamp.
Oct 15, 2009 | Starrett 50443 12 Machinists' Improved...
Hi. I just received a Starrett 98Z12 machinist
Sit level on near level surface. Observe bubble position. Turn level end for end. Does bubble sit at same position? If not adjust screw untill they match. Test, adjust and so on.
Aug 06, 2009 | Starrett 50443 12 Machinists' Improved...
How do you replace the bubble in a starrett 98 Level
Contact me at Starrett and I can email you the instructions on how to change the vial only if you want. The other option is to purchase a new tube and plug assembly (the silver tube with the vial). That is much easier to do. After, you can always send the old one in for repair. Third option is to send out the tube and plug assembly to be repaired.
Most people will change the vial only the first time, after that they go with option 2 or 3.
My email is
May 04, 2009 | Starrett 50443 12 Machinists' Improved...
Micrometers out of calibration
Micrometers must be calibrated at 4 spots around the barrel and at zero and full scale to be truly accurate. You will have to send it to a calibration lab or back to Starrett for a full calibration because they will check it with gauge blocks of known length and verify the spindle and anvil surface flatness.
If you are only concerned with the zero and not as much about the full accuracy of the tool, then you can reset the zero yourself. With the mic fully closed (spindle and anvil touching), turn the barrel with the funky, half circle shaped wrench that came with the mic in the box. There is a little hole in the barrel where the nub on the wrench will fit then you just turn it until it reads zero. Good luck.
Mar 07, 2009 | Starrett T216XRL-1 - MICROMETER, DIGITAL
Pls5 Accuracy problem
I will double check but pretty certain it was just out of adjustment in some way.
Aug 30, 2008 | Pacific Laser Systems PLS5 Automatic Laser...
Measuring Accuracy Problem
Use a second measuring tool and compare the results, or you can measure a known size or length (floor tiles for example)and check the reading you get.
Aug 27, 2008 | Stanley 100 ft. Tape Measure, FatMax
Measuring Tools & Sensors Logo
481 people viewed this question
Top Starrett Measuring Tools & Sensors Experts
Vernon Taylor
ray gallant
Are you a Starrett Measuring Tool and Sensor Expert? Answer questions, earn points and help others
