Question about White Sewing Speedylock 1600 Mechanical Sewing Machine
Knocking noise machine is knocking [against something] and not making any stitches. I slowly turned the knob to try to see what's hitting, but to no avail. Thanks in advance for any response,
  • bedbugs Mar 10, 2009
    knocking noise on my serger won't stitch and I can't afford to send it away for repairs can anyone offer me some advice
    Problem Solver:
  • 4 Answers
Too little info. but a common cause of knocking is the loopers hitting or rubbing each other, an out of time issue. unfortunately i would recommend that you take it to a qualified repair shop to avoid greater damage.
Posted on Jan 28, 2009
We got Juki DDL8100E. Few days ago. when sewing, needle broke and since then our machine is making heavvy noise. Also, the Stitch adjuster knob is vibrating up and down. please help
check that a bit of the broken needle is not interfering with the bobbin case movement
if the breakage was hard enough it may have altered the needle / hook timing which will cause a knocking sound as well
Aug 20, 2016 | Juki Sewing Machines
My singer heavy duty 5532 makes a knocking noise when I use the decorative stitches
check thread and make sure thread has been in its threading slot in your bobbin case
Mar 23, 2016 | Singer 5532 32-Stitch Heavy Duty Sewing...
The machine is stuck in zigzag cannon move control knobs
If the buttonhole dial has been rotated so that its indicator mark is not at zero (vertical aligned with the plate indicator mark), the stitch width dial will not function. Turn the buttonhole dial clockwise to the vertical mark.
SewTechnical Home
Jun 05, 2014 | Bernina Sewing Machines
Singer serger 14u
Sounds like your needle is hitting the needle plate instead of going through the tiny hole down to the bobbin. Try using the handwheel slowly and watch. Or perhaps the needle is hitting the bobbin case. Something has been knocked off the straight I think. Has your machine been dropped or dmamaged?
Oct 15, 2013 | Sewing Machines
Viking 1+ Horizontal movement quit working after needle hit something
it sounds like you knocked the machine out of time & it will have to be taken to a
sewing machine shop to be retimed
Apr 26, 2012 | Sewing Machines
I want to know which knob I use to make the stitching narrower
there are generally two variable controls .. one adjusts the stitch length (distance between stitches measured in stitches per inch) ... the second is stitch width .. that adjusts how far the zigzag moves left and right .. thats usually just a number from 0 to 10 or so .. 10 would be maximum width .. 0 would be used for straight stitch ..
so you need to adjust the stitch width control to make the stitching narrower .. the controls are called different things on different brand sewing machines .. if you have the brand and model number then there may be instruction booklets available ...
Jan 04, 2010 | Sewing Machines
Knocking noise when sewing
If the machine does not knock when in straight stitch then it is the stitch width limiter. You would have to take off the side cover with a T20 torx screwdriver. Once open you will see an elongated U-shaped piece with a screw through the bottom of it (its maybe a half inch long or so). Its just above that big bottom thread guide. I think you need a T10 torx driver, loosen that screw and move that u-shaped part slightly (very slightly) so it isn't hitting anymore on the side to side action. It happens but can't really harm anything.
I'm sure thats it.
Nov 09, 2008 | Bernina Virtuosa 150
Machine makes a loud noise and will not make stitches.
sounds like something is broken. best to get it checked out. take to the sewing machine doctor.
Oct 16, 2008 | Brother CS-8150 Computerized Sewing...
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
297 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
